Thread started 08 Aug 2003 (Friday) 21:45
To Tannoy: Tamrac Vel. 9 Fit.
Leigh
Joined Apr 2003
Aug 08, 2003 21:45 |  #1
Hi Darren,
I was about to purchase a Velocity 9 bag, and came upon your posted reply on the subject.
I assume that the tight fit "problem" is with the internal depth of the bag, which Tamrac spec.s at 6 3/8", and not about adequate space obove the camera?
I've been using a LowePro TLZ Pro with an Elan 2E/Battery Grip/100-400IS attached, and both a Zing "sling" grip. and Optech strap attached--- snug, but OK in the LowePro.
I've been holding off until Sept. on a DLSR, to see what Canon comes out with, and will make the plunge then to one or another.
I generally pack the 100-400, 28-135, Tamron 90mm Macro, and with digital--likely an additional WA Zoom.
I wondered if you are describing merely a "snug" fit, or do you consider it would be a hassle to quickly remove / install--say- a 10D/BG3 with 100-400 IS attached, and the other lenses in the bag?
Any additional feedback would be most appreciated.
Best regards,
Leigh
1,265 views & 0 likes for this thread.
1457 guests, 129 members online
