Hello, I have just posted my first message after lurking for a while, and I ran across a problem that I have not experienced on other vBulletin boards where I am a member. The problem is that when I hit the Enter key twice to start a new paragraph, the board apparently strips out those keystrokes and runs everything into a single, run-on paragraph. On the other vBulletin boards I use, when I start a new paragraph, it shows up with a blank line between it and the paragraph above. For example, this message was four separate paragraphs when I composed it, but look at it now! Clearly I have something set wrong, but I have not seen this before, and I don't know how to fix it. Thanks for your help (paragraph 5!).
