Dual drive dock with USB-C; see https://www.anandtech.com …rive-dock-with-usb-type-c
JohnfromPA Cream of the Crop 11,257 posts Likes: 1526 Joined May 2003 Location: Southeast Pennsylvania More info | Dec 10, 2018 09:26 | #1 Dual drive dock with USB-C; see https://www.anandtech.com …rive-dock-with-usb-type-c
el_duderino04 Member 40 posts Likes: 3 Joined Nov 2018 Location: Pasadena, CA More info | Dec 11, 2018 01:40 | #2 I have a similar one that's just USB 3. It's a great way to quickly plug/unplug drives. I've been meaning to pick up some more SSD drives now that prices are coming down to use as project-specific backups (in addition to my main backups). USB C would be even better than mine given the increased speed potential.
tim Light Bringer 51,010 posts Likes: 375 Joined Nov 2004 Location: Wellington, New Zealand More info | Dec 14, 2018 01:07 | #3 I use something similar, an Sabrent dock Professional wedding photographer, solution architect and general technical guy with multiple Amazon Web Services certifications.
el_duderino04 Member 40 posts Likes: 3 Joined Nov 2018 Location: Pasadena, CA More info Post edited over 4 years ago by el_duderino04. | Dec 14, 2018 11:24 | #4 tim wrote in post #18770583 I use something similar, an Sabrent dock I put my backup disks into Orico disk cases I got sick of hard drive enclosures, which I find last a year or two even if you only use them once a month. I hear you on enclosures, somehow they never seem to last. I've been toying with the idea of a similar case for an SSD, plus a cable like this
tcphoto1 Goldmember More info | Dec 16, 2018 09:47 | #5 I suppose those docks would work if you rely on a stack of loose HD's as your backups. I prefer an organized stack of external drives that I know what is on it and is chronological plus is paired to another stack for redundency. Image hosted by forum (950382) © tcphoto1 [SHARE LINK] THIS IS A LOW QUALITY PREVIEW. Please log in to see the good quality stuff. www.tonyclarkphoto.com
RDKirk Adorama says I'm "packed." More info | Jan 20, 2019 12:41 | #6 Why do external docks and enclosures fail? TANSTAAFL--The Only Unbreakable Rule in Photography
el_duderino04 Member 40 posts Likes: 3 Joined Nov 2018 Location: Pasadena, CA More info | Jan 25, 2019 15:08 | #7 RDKirk wrote in post #18795314 Why do external docks and enclosures fail? And fail, they do. But they're simple to build. Infant mortality, I could see, but beyond that an electronic device that works beyond infant mortality tends to keep working. Why do docks and enclosures always fail so quickly. I would think that most failures (beyond "infant mortality") are due to inadequate cooling. There are a number, however, that just have latent issues that can cause a failure beyond infancy but long before they should. The most concerning are failures that cause a total loss of data, but I would think that would likely be due to problems with the drive itself rather than the enclosure.
Wilt Reader's Digest Condensed version of War and Peace [POTN Vol 1] More info Post edited over 4 years ago by Wilt. (4 edits in all) | Jan 25, 2019 17:10 | #8 RDKirk wrote in post #18795314 Why do external docks and enclosures fail? And fail, they do. But they're simple to build. Infant mortality, I could see, but beyond that an electronic device that works beyond infant mortality tends to keep working. Why do docks and enclosures always fail so quickly. Methinks that often the external enclosures are cheaply designed, and when made by outfits like Western Digital, they primarily exist as a means of increasing volume of harddrives. They do not care if a 'failed unit' means another enclosure with harddrive, even though the harddrive itself in the failed unit is truly healthy. You need to give me OK to edit your image and repost! Keep POTN alive and well with member support https://photography-on-the.net/forum/donate.php
el_duderino04 Member 40 posts Likes: 3 Joined Nov 2018 Location: Pasadena, CA More info | Feb 01, 2019 17:28 | #9 Wilt wrote in post #18798462 Methinks that often the external enclosures are cheaply designed, and when made by outfits like Western Digital, they primarily exist as a means of increasing volume of harddrives. They do not care if a 'failed unit' means another enclosure with harddrive, even though the harddrive itself in the failed unit is truly healthy. I had a WD Mybook that I powered up only to backup data, then power down. I do not consider its failure to be 'infant mortality' as I had left it powered up constantly before I converted its use into backup service (with power only when needed). It failed to initialize itself after a power up, and I hacksawed the harddrive out of the enclosure and put it into a docking unit and the harddrive worked fine; it still works even now. I have a Seagate external that suddenly failed to be recognized by my computer when plugged in. Maybe I'll try the hacksaw "repair" as well.
bolocal Hatchling 3 posts Joined Feb 2019 More info | Wow never even thought that could work, thanks for the tip Always exploring Oregon
el_duderino04 Member 40 posts Likes: 3 Joined Nov 2018 Location: Pasadena, CA More info | Feb 01, 2019 18:21 | #11 bolocal wrote in post #18802894 Wow never even thought that could work, thanks for the tip You'd definitely want to be careful not to damage the drive when you pull apart the enclosure. Rather than just sawing it, I would think trying to gently pry apart the enclosure would be less likely to harm the drive inside.
Wilt Reader's Digest Condensed version of War and Peace [POTN Vol 1] More info | Feb 01, 2019 18:52 | #12 el_duderino04 wrote in post #18802897 You'd definitely want to be careful not to damage the drive when you pull apart the enclosure. Rather than just sawing it, I would think trying to gently pry apart the enclosure would be less likely to harm the drive inside. I had dissassembled the WD MyBook housing as far as I could...removed all screws, brackets, etc. that could be removed. The two halves were joined in a rather inexplicable way, that only could be separated by hacksawing the metal bracket joining the two halves. I was very careful in verifying that this was all that prevented to removal of the harddrive itself. Hacksaw allowed separation of the two halves and easy removal of the harddrive from its connector in one of the halves. You need to give me OK to edit your image and repost! Keep POTN alive and well with member support https://photography-on-the.net/forum/donate.php
el_duderino04 Member 40 posts Likes: 3 Joined Nov 2018 Location: Pasadena, CA More info | Feb 01, 2019 18:58 | #13 Wilt wrote in post #18802921 I had dissassembled the WD MyBook housing as far as I could...removed all screws, brackets, etc. that could be removed. The two halves were joined in a rather inexplicable way, that only could be separated by hacksawing the metal bracket joining the two halves. I was very careful in verifying that this was all that prevented to removal of the harddrive itself. Hacksaw allowed separation of the two halves and easy removal of the harddrive from its connector in one of the halves. Interesting, I'll keep that in mind in case mine has a similar construction. Thanks!
Bcaps I was a little buzzed when I took this More info Post edited over 4 years ago by Bcaps. | Feb 14, 2019 15:55 | #14 Wilt wrote in post #18802921 I had dissassembled the WD MyBook housing as far as I could...removed all screws, brackets, etc. that could be removed. The two halves were joined in a rather inexplicable way, that only could be separated by hacksawing the metal bracket joining the two halves. I was very careful in verifying that this was all that prevented to removal of the harddrive itself. Hacksaw allowed separation of the two halves and easy removal of the harddrive from its connector in one of the halves.
- Dave | flickr
| Latest registered member is Mihai Bucur 1056 guests, 117 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
