This morning I was going to print 8 x 10 family photos (Christmas presents) on Canon Pro Platinum Photo Paper on my Canon Pixma Pro-100 printer when I made a horrible mistake. I have never used this paper before and when I loaded the rear tray I inadvertently loaded the piece of cardboard that was inside the plastic along with the photo papers (the photo paper is rather thick and the cardboard is thin & I just didn't notice it). Only after I saw the horrible ink-smeared output did I realize what had happened (see below).
STOP LAUGHING. I MEAN IT.
The paper was literally smeared with gobs of glistening wet ink. I have since spent nearly all day cleaning the printer and looking up information online. So far I have run all of the Canon printer utilities as well as (a) removing the sponge (with ink-soaked spots), washing it, drying it, and reinstalling it; and (b) cleaning ink-smeared areas of plastic with Q-tips & alcohol swabs.
I have run the Bottom Plate Cleaning utility about 50 times and every time I run it I STILL get ink spots on the folded paper that you run through the printer as part of this program (see photo of what I am getting below).
The inside of the printer looks OK, and the other utility programs are coming out OK, but it seems to me that if the bottom plate were actually clean I would be getting clean papers coming out when running the Bottom Plate Cleaning utility. Yet I do not.
Does anyone know if this is normal? I have googled this question and looked at the manual & perused Canon support documents and I can find the procedure for Bottom Plate Cleaning but I can not find whether or not you are supposed to keep doing it until the output paper is clean.
If anyone knows the answer to this I would really appreciate a reply. Otherwise I am going to be running this utility forever in an apparently futile quest for a clean output.
Or writing my runaway best-seller: Really, Really Bad Family Photographs.
