Thread started 20 Dec 2018 (Thursday) 11:58
Good 10' - 11' Light Stands?
GESWhoPhoto
Joined Sep 2017
Dec 20, 2018 11:58 |  #1
Hey all,
I ordered a set of these light stands last year off Amazon: https://www.amazon.com …_detailpage?ie=​UTF8&psc=1 (external link)
They are fantastic. Super smooth, they disassemble very compact, and are ten feet when fully extended.
However, for the life of me, I cannot find good light stands off Amazon nowadays! I have ordered 3 different brands; anywhere from 9'6" to 10'6", and they are all either very flimsy, manufactured too tight on the tolerances to where I have to TUG to get sections to extend, or the tripod legs do not stay in position once a light is placed on the stand (small speedlight, mind you).
Does anybody have a recommendation for 2-3 high-quality, but affordable, 10' - 11' light stands? Will mostly be used for V860II-N or maybe an AD200 + accessories.
Thanks in advance!
V/r, Garrett
Current:
D850 | D750 | MB-D16 | Nikon 70-200 f/2.8 E FL ED VR | Nikon 24-70 f/2.8 E VR | Nikon 105 f/2.8 G VR Macro | Rokinon 12mm f/2.8 Fisheye | Nikkor 50mm f/1.8 | 5x Godox V860II-N | 1x Flashpoint XPLOR 600 PRO |
ksbal
Gallery: 374 photos
Best ofs: 9
Dec 20, 2018 12:11 |  #2
I'm not sure how compact these are, but I have a set for a bg and I know they are sturdy.
Linco Light Stand (external link)
Godox/Flashpoint r2 system, plus some canon stuff.
GESWhoPhoto
Joined Sep 2017
Dec 20, 2018 13:16 as a reply to  @ ksbal's post |  #3
Sweet! Amazon has these! You're a fan? Don't find the super wide base too intrusive?
V/r, Garrett
Current:
OceanRipple*
Joined Dec 2014
Dec 20, 2018 13:31 |  #4
ksbal wrote in post #18774733 (external link)
Hi, If that claimed 132 cm Footprint diameter is genuine (& I've no reason to doubt it), then that is quite generous and appropriate for a ten foot stand. If anyone wanted to retro-fit castors, it looks as though the legs at their widest, don't make 45 degrees with the floor - meaning that they would have to be pinched up slightly to accept standard castors (not necessarily a deal breaker).
TeamSpeed
01010100 01010011
Gallery: 116 photos
Joined May 2002
Dec 20, 2018 13:38 |  #5
I have been considering switching to C stands like this: https://www.amazon.com …fRID=7E236RQF2Y​K9SBM319XH (external link)
NDAPhoto
Joined Jul 2015
Post edited over 4 years ago by NDAPhoto. (2 edits in all)
Dec 20, 2018 14:32 |  #6
The PBL stands are still available from stevekaeser.com. http://www.skaeser.com …heavy-duty-air-cushioned/ (external link)
The Linco stands are very good, particularly as a background support. Just know they are steel, not aluminum. So the tubes are stronger, but skinnier. They are also gunmetal color, not black.
Another brand under $100 for a pair is Lumopro from Midwest Photo. This is a reputable vendor and the stands are reliable and often recommended. https://mpex.com …ushioned-light-stand.html (external link)
ksbal
Gallery: 374 photos
Best ofs: 9
Dec 20, 2018 16:31 as a reply to  @ GESWhoPhoto's post |  #7
Sometimes, yes, the super wide base can be an issue, so I try to adjust it.. this would be more of a problem if you are using narrow bg, but I tend to be using from 10 to 20 ft back grounds.. I hang extra pipe on either side of the 12ft bar without issues. Wide foot print sometimes is handy, when I have a bit of a breeze in the barn.
I need a C stand or two, but rather haul these around than a set of those, for sure. The bg set I got folds up nice in a slim profile.
Lotto
Dec 21, 2018 00:22 |  #8
Don't know if the OP had tried this, but after Amazon bombarded my inbox with ads of this stainless steel light stand, I ordered one to see the differences comparing to a aluminum one.
https://www.amazon.com …fRID=1111CQ2CP7​SJVCVJY205 (external link)
All metal construction. The clamp/brake has good quality parts, combining with the smooth stainless raiser tube, it is the 'loosest' stand I have. I mean with 1/4 turn of the knob, change the raiser from free falling to solid lock up. And it's stronger than the PBL stand that I also own.
@TeamSpeed, the C stand in you link has a different size stud at the bottom the raiser, so it could be a problem if you want to switch the stand base to different brands later, like the Kupo Runway base pictured below.
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2018/12/3/LQ_951239.jpg
Image hosted by forum (951239) © Lotto [SHARE LINK]
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2018/12/3/LQ_951240.jpg
Image hosted by forum (951240) © Lotto [SHARE LINK]
5D, 24-105L, 70-200L IS, 85mm Art, Godox
TeamSpeed
01010100 01010011
Gallery: 116 photos
Joined May 2002
Post edited over 4 years ago by TeamSpeed.
Dec 21, 2018 06:55 as a reply to  @ Lotto's post |  #9
Great info, thanks!
I was thinking about just getting casters for the stand legs, do they work or should I really consider something else, like a dedicated dolly/caster setup for the stands?
I am getting really tired of moving the stands around as I cycle through couples vs large families and then I have to move lights and then set power on the transmitter for the strobes. Wheels would be much better.
Lotto
Dec 21, 2018 12:29 |  #10
I have been using a aluminum stand with casters for my main light for years, and probably would have not gotten the runner base if I don't own a C stand with the turtle base. Yes, wheels make fine tuning the lights position lot easier, and less of chance got knock over.
Couple things I notice when I made the switch to C stand raiser + runner base beside the pay load..
1) Because of tiny flex on the aluminum stand's legs, there is this slight jerky motion when I first start to
move the stand, till the wheels all align to one direction. The runway base is solid and very smooth.
2) One reason I like about the C stand is the smaller foot print. The Kupo rolling base has the same leg spread as the turtle base. Though not as easy to sand bag, it can take on lot of weight.
If you need to boom something heavy, I would suggest a junior stand on wheels.
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2018/12/3/LQ_951316.jpg
Image hosted by forum (951316) © Lotto [SHARE LINK]
GESWhoPhoto
Joined Sep 2017
Dec 21, 2018 14:11 |  #11
NDAPhoto wrote in post #18774834 (external link)
They're out of stock at skaeser.com, unfortunately :-( but I do appreciate the information! I ordered the Lincos to try out, hopefully they work for my wedding photography! Just need to sit pretty in the corner of a reception hall and hold a speedlight. :-P
The Lumopros look like they would also work well! Going to keep that in mind in case I don't like the Lincos.
V/r, Garrett
Current:
bobbyz
Dec 22, 2018 08:51 |  #12
Adorama has flashpoint stands which are cheaper. There is kupo which is also nice. But after using Avenger, Mathews etc, I just spend a bit more and stick with mathews.
https://www.bhphotovid​eo.com …Maxi_Kit_Steel_​Stand.html (external link)
Personally I think spending money on quality grip gear is worth it. Folks have the latest cameras, L lenses and cheap out on lighting gear. Why not make you life easier if you can afford it. And the good stuff lasts forever. My Avenger wheeled stand cost me close to $300 and i have been using it outdoors for 10 yrs.
Fuji XT-1, 18-55mm
NDAPhoto
Joined Jul 2015
Dec 22, 2018 09:54 |  #13
OP asked for a pair of affordable 10’ stands to hold speedlights like the PBLs. C stands and junior stands are overkill at 4x his budget.
NDAPhoto
Joined Jul 2015
Dec 22, 2018 10:00 |  #14
GESWhoPhoto wrote in post #18775468 (external link)
Good choice and Linco is good with service if you need it. Note the Lincos are spring cushioned while the PBLs are air-cushioned. They also pack tighter which is nice for transport.
TeamSpeed
01010100 01010011
Gallery: 116 photos
Joined May 2002
Dec 22, 2018 11:01 |  #15
NDAPhoto wrote in post #18775958 (external link)
How do we know the budget? I didn't see any budget listed. Having many cheap and good more expensive options are always good for consideration IMO.
5,901 views & 7 likes for this thread, 13 members have posted to it and it is followed by 9 members.
1501 guests, 131 members online
