Hello hivemind...
I have a question... Quite a while ago, when I had my T3i (2012) I purchased the aforementioned Metz 50 AF-1. It worked flawlessly on my T3i on or off camera. Similarly, when I upgraded to my 7D, it also worked flawlessly. Recently, I had a need for a flash on my 5D4 so I busted out the Metz. I did not test it before I used it (I probably should have). I attached it to the 5D4 but the recycle time was uber slow in both eTTL and M modes. I added brand new batteries with the same result. I did loads of google searches with no results. One of the things I did read in the online manual is that the flash needs to turn on and be discharged every 3 months - which I did not do. So, I lived with it while I needed it on the road. I have since sold my T3i but I did test the flash on my 7D. It, again, worked flawless. Cycles super fast and I can take multiple photos in a row with the flash functioning. I put it on the 5D4 again and we are back to slow cycle times and loads of waiting. The Metz has the latest firmware which supports 5D3 (and later). The 5D4 has the previous firmware 1.0.4. The flash works as it should on the 7D but not on the 5D4. Does anyone have any thoughts on directions I should take or suggestions outside of buying a new flash? I can do just that but I would like to explore this functioning with my current cameras. I suppose I can contact Metz for support but I figured if there was someone who may have encountered a similar issue...
Thanks in advance!
) because I wanted to try some of the new fangled features after I tested it quickly. As you could have guessed based on my opening run-on sentance, the flash works perfectly. Therefore, my conclusion is that the old Metz is not compatible with the 5D4. I will hang on to it as it might be useful with some remote triggers perhaps and because it's not worth much to try and sell. Mystery solved and time to go shopping.
