Thread started 09 Jan 2019 (Wednesday) 04:23
Extender II or III questions
guus ­ verheijen
Jan 09, 2019 04:23 |  #1
I am quite fond of using the TC 1.4X and TC 2X (both version II} with my EF 400mm F2.8 L IS USM (NOT version II) for Wildlife Photography. I am told that I should see a noticeable IQ improvement with especially the TC 2X III. Anybody made the comparison?
Recently an EF 100-400mm L IS USM arrived in the family, which I tried with the TC 1.4X II with rather promising results. This triggered the following questions:
Has anybody made a direct comparison of the performance (IQ, AF…) of the EF 100-400mm L IS USM II with the TC 1.4X II and TC 1.4X III ? Is there a genuine benefit in purchasing version III?
For completeness: The Cameras involved are the 7D and 7D MKII.
I appreciate your inputs,
Thanks in advance
TeamSpeed
01010100 01010011
Gallery: 116 photos
Joined May 2002
Post edited over 4 years ago by TeamSpeed.
Jan 09, 2019 05:31 |  #2
Yes and the consensus was that there was very little difference in IQ on the 1.4, the difference was more about AF speed with some lenses.
The 2x was different, the mk III provides a noticeable IQ difference as well as AF speed.
This is all contingent on my memory being correct on past discussions though. :)
umphotography
grabbing their Johnson
Gallery: 21 photos
Jan 09, 2019 08:00 |  #3
TeamSpeed wrote in post #18787748 (external link)
^^^^^^This^^^^^^
I use a 1.4II and no difference s tat I can see
I have a sigma 2.0 that seams to do as good a job as the 2.0 III from a couple of posts that I have seen. But I rarely ever use the 2.0. I see enough of image breakdown when I crop in that I just dont use it
Mike
www.umphotography.com (external link)
Facebook (external link)
John ­ Sheehy
Jan 09, 2019 08:45 |  #4
umphotography wrote in post #18787789 (external link)
^^^^^^This^^^^^^
Let me ask something here.
Do you step back twice as far from the subject when you put a 2x on, when you'd rather be at the original perspective?
Otherwise, I can't make any sense out of your statement. From the same perspective, the shot with the 2x needs to be cropped half as much, as without it. A 2x shot downsized to 50% has so much more color resolution and so little potential for color moire. A 2x shot also overrides the problem when you try to crop from JPEGs, where fine details are often scrubbed by noise reduction. 2-pixel-wide details make it through the NR much better than 1-pixel-wide ones. The only major negative to me about a quality TC as opposed to harder cropping is possible loss of AF speed, accuracy, or function. If you have a dirty sensor, then I guess a TC can also make the dirt shadows deeper, even if smaller in overall size relative to the subject size).
TC also makes the effect of an AA filter smaller on the subject, without increasing alaising, but actually decreasing aliasing.
digital ­ paradise
Awaiting the title ferry...
Gallery: 157 photos
Jan 10, 2019 04:36 |  #5
I found less CA with version III. Also with newer lenses like your 100-400 II will benefit with faster AF speeds.
https://www.the-digital-picture.com …r-EF-1.4x-III-Review.aspx (external link)
A few other threads.
https://photography-on-the.net …/showthread.php​?t=1130578
https://www.fredmirand​a.com/forum/topic/1126​403/ (external link)
Image Editing OK
Tom ­ Reichner
"That's what I do."
Gallery: 213 photos
Location: from Pennsylvania, USA, now in Washington state, USA, road trip back and forth a lot
Jan 12, 2019 13:15 |  #6
guus verheijen wrote in post #18787735 (external link)
I am quite fond of using the TC 1.4X and TC 2X (both version II} I am told that I should see a noticeable IQ improvement with especially the TC 2X III.
Whoever told you that is full of it. . The differences between the v2 and v3 tele-extenders are only realized with the v2 and v3 lenses.
There have been a ton of online sources that have all said this from the very start of the v3 extenders. . Whoever told you otherwise doesn't know what they are talking about and shouldn't be listened to or paid any attention to. . I hate it when unknowledgeable buffoons lead others astray.
Yeah, I have the same lens as you.
I have shot my 400 f2.8 IS version 1 with both the 2xv2 and the 2xv3. . No difference at all. I only bought the v3 because it was a really good deal and I could resell it for a profit.
ed ­ rader
"I am not the final word"
Jan 12, 2019 15:01 |  #7
AF speed and accuracy has a massive effect on IQ.
5D4 x2, 16-35L F4 IS, 24-70L II, 70-200L F4 IS II, 100-400L II, 14L II, sigma 15 FE, sigma 28 f1.4 art, tc 1.4 III, 430exII, gitzo 3542L + markins Q20, gitzo GT 1545T + markins Q3T, gitzo GM4562
filam
Gallery: 338 photos
Joined Jun 2011
Post edited over 4 years ago by filam.
Jan 12, 2019 16:04 |  #8
I replaced my 1.4x v2 with the v3 and did notice an improvement in CA and image quality straight away. I'm using it on my 600 f4 is mk1 it's hard to tell I have it on its so much better and worth upgrading. If you don't you will always be thinking about it.
Canon 1DX 5Dmk3 Canon 600mm f4L IS
Canon 70-200mm f4L IS Canon 50mm f1.8II
Canon 16-35mm f4L IS
Gitzo GT5532S Tripod - Wimberly WH-200 mkII
https://www.instagram.​com/hongleungphotograp​hy/ (external link)
https://www.instagram.​com/hongleungwildlifep​hotography/ (external link)
digital ­ paradise
Gallery: 157 photos
Jan 12, 2019 16:11 |  #9
Not a noticeable difference between VII and VIII.
Image Editing OK
johnf3f
Post edited over 4 years ago by johnf3f.
Jan 12, 2019 17:41 |  #10
Tom Reichner wrote in post #18790159 (external link)
Tom please correct me if I have read your post wrong, but are you saying that there is no difference (AF/IQ) between the Mk2 and Mk3 Canon 2 x extenders on Mk1 lenses?
The reason I ask is that this markedly goes against my (and a couple of others) experiences. Note none of the lenses (300 F2.8 L IS, 300 F4 L IS, 600 F4 L IS, 500 F4 L IS, 800 F5.6 L IS - manual focus, 400 F2.8 L IS etc etc) were Mk2 variants and none of the cameras (according to Canon) were capable of benefiting from the enhanced AF performance of the 2 x Mk3 extender. Yet, in all cases, the Mk2 extenders were sold ASAP due to the IQ and (slight but significant) AF improvements of the Mk3.
Naturally on the latest cameras and lenses the Mk3 extenders are even better - but even on the older stuff the 2 x Mk3 extender is MUCH better than the Mk2 in my, and a few others, experience.
With the 1.4 it is somewhat different as the Mk2 is better in the centre of the image, though with new gear, the Mk3 is better overall,
Life is for living, cameras are to capture it (one day I will learn how!).
John ­ Sheehy
Jan 13, 2019 05:27 |  #11
ed rader wrote in post #18790231 (external link)
I see no reason to mix maximum possible IQ and AF success. Does a system with a razor-sharp manual focus lens have no IQ?
It pains me to see how much of people's reporting of their disappointing experience of TCs does not isolate AF from optics.
Even if AF and optics are separated, many people still don't seem aware of the difference between a TC exposing the main lens' weakness and showing more diffraction at the pixel level, vs added aberrations from the TC. The former is a good thing, really, whether people immediately realize it or not, with their pixel-level standards. The latter actually subtracts a little bit from the TC use, but for some purposes, more pixels-on-subject is useful, even if some small amount of global or micro contrast is lost.
John ­ Sheehy
Jan 13, 2019 05:36 |  #12
filam wrote in post #18790273 (external link)
This is not commonly reported, as I remember, so perhaps there was something wrong with your 1.4xII? Sometimes TC front elements start to unscrew and loosen, or maybe it passed QC inspection the afternoon of a retirement party at the factory.
John ­ Sheehy
Jan 13, 2019 05:37 |  #13
digital paradise wrote in post #18790285 (external link)
We're up to seven and eight already? ;-)a
2,339 views & 3 likes for this thread, 9 members have posted to it and it is followed by 4 members.
1060 guests, 104 members online
