Thread started 18 Jan 2019 (Friday) 18:06
Godox Xpro-C Trigger Overexposing
drisley
"What a Tool I am"
Joined Nov 2002
Post edited over 4 years ago by drisley.
Jan 18, 2019 18:06 |  #1
A while back I purchased a Good Xpro-C TTL Wireless Flash Trigger for my Canon 5D Mark IV. I hadn’t used it for a while and today I decided to give it a go and for some reason, when in M mode, the power, even at 1/128 is way too much.
If I use TTL mode, the flash fires fine (I can even underexpose with an exposure adjustment), and powers down. But always in M mode it’s just way too much. At 1/1 I just get a white picture, at 1/128, it’s still extremely overblown and overexposed (but less than 1/1 so I know it is powering down somewhat). Why can TTL mode power down properly but 1/128 Manual power is way too much? Could I be missing something?
I tried with 2 different Godox TT685C flashes (set to Slave A CH1) and the same result. Could I be missing something? It's been about 8 months since I used these (tried different batteries in each).
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2019/01/3/LQ_956554.jpg
Image hosted by forum (956554) © drisley [SHARE LINK]
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2019/01/3/LQ_956555.jpg
Image hosted by forum (956555) © drisley [SHARE LINK]
EOS R6 Mark II - Sigma 50/1.4 Art - Sigma 14-24/2.8 Art - Canon EF 70-200/2.8L Mark III - Godox Xpro-C - Godox TT685C x2
drisley
"What a Tool I am"
Joined Nov 2002
Jan 18, 2019 19:17 |  #2
Edit: This is also the case when using these flashes on camera... 1/128 M is too powerful for almost any use unless I set about ISO100 and F2.8 or higher.
TeamSpeed
01010100 01010011
Gallery: 116 photos
Joined May 2002
Jan 18, 2019 20:14 |  #3
Do you have FEC set to something? It would affect TTL and not if you are in manual mode.
Lotto
Jan 19, 2019 02:44 |  #4
drisley wrote in post #18794317 (external link)
From my experience with Canon eTTL speedlites, the flash in ttl mode can go at lease couple stops below 1/128.
I don't think there is any thing wrong with your flash. My flashes do the same with too high of ISO, too close, and lens wild open.
What are you try to shoot beside quick tests with those camera settings?
5D, 24-105L, 70-200L IS, 85mm Art, Godox
drisley
"What a Tool I am"
Joined Nov 2002
Jan 19, 2019 13:57 |  #5
I was trying to shoot a kitchen shot with some ambient and large aperture.
I've tried on camera with 2 different TT685's and my 1D and 5D... both produce the same effect. Manual 1/128 is way too powerful, but ETTL is fine.
soeren
"only intermitent functional"
Joined Nov 2017
Jan 19, 2019 14:00 |  #6
It is very close to your "subject"
If history has proven anything. it's that evolution always wins!!
gonzogolf
dumb remark memorialized
Gallery: 561 photos
Jan 19, 2019 14:07 |  #7
Add some diffusion. You would be amazed at how much difference a couple of layers of tissue paper will make
Lotto
Post edited over 4 years ago by Lotto.
Jan 19, 2019 18:21 |  #8
Boring Saturday afternoon, want to find ways to properly expose @ ISO 400, F1.8, and 1/160 with the Godox speedlight at minimum power...
A simple bounce off the ceiling would do, but that's not the POTN way  :p
4 layers of tissue paper is still too bright at close distance.
IMAGE: https://farm8.staticflickr.com/7883/32930540108_5444ea0e92_b.jpg
With 4 layers of tissue in a double diffused softbox should do!
IMAGE: https://farm8.staticflickr.com/7909/32930535278_303da82afa_o.jpg
Saturday is not that boring after all:-)
drisley
"What a Tool I am"
Joined Nov 2002
Jan 19, 2019 20:38 as a reply to  @ Lotto's post |  #9
Thanks guys! Thanks LOTTO! Ok I didn't realize this was just the way the flash were set up. It's weird that after owning many flashes (430EX, some Yongnuos, and now these Godox) I've never notice the flash being too bright in M mode.
Thank you for all your help! :)
SereneSpeed
Joined Jan 2013
Jan 20, 2019 21:25 |  #10
Did you try at ISO 100?
Also, bumping the shutter speed above 1/200th will give you a 1-1/3 stop reduction in flash power as the flash switches to a pulsing mode to work with HSS (High Speed Sync).
The 430's are great flashes, but not nearly as powerful as the ex600's and the yn600's (or any Yongnuos that I am aware of) are at least 1 stop less powerful than the ex600's. The Godox speedlights have a lot of power.
https://www.danbcreati​ve.com (external link) - Commercial Work
http://unabashedbeauty​.com (external link) - Boudoir/NSFW
drisley
"What a Tool I am"
Joined Nov 2002
Jan 21, 2019 15:27 as a reply to  @ SereneSpeed's post |  #11
Good point, I could go to high speed sync. I was just a bit surprised that the flash was so powerful. I kind of wanted some ambient in and drag the shutter a bit. I thought the 1/128 would be low enough to put in some some colour/gel flash in places.
Pictoraider
Joined May 2016
Feb 14, 2019 04:11 |  #12
drisley wrote in post #18796038 (external link)
HSS High Speed Sync is only available if the working shutter speed is faster than your camera max sync-X shutter speed : in available low light, it is not realistic to carry out HSS flash lighting.
If you want to shoot with your TT685 flash in manual mode, you have to minor by some way the actual manual minimal ouptput of the flash or have to increase the working distance flash-to-subject.
For daily personal photo practise, my old 550EX Canon flash is covered by homemade modyfier so to have GN precisely equal to 5,6m at 1/4P for 100 ISO - with around 1/1200 s flash duration.
We all are subjects to basics :
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2019/02/2/LQ_961253.jpg
Image hosted by forum (961253) © Pictoraider [SHARE LINK]
Regards,
"Constructive criticism always appreciated."
soeren
Joined Nov 2017
Post edited over 4 years ago by soeren. (2 edits in all)
Feb 14, 2019 04:22 |  #13
Pictoraider wrote in post #18810756 (external link)
Hosted photo: posted by Pictoraider in
./showthread.php?p=188​10756&i=i106756078
forum: Flash and Studio Lighting
Regards,
Ehh what???? You can carry out HSS in any light you want provided the flash has the power to either light up your subject or overpower the sun AND light up..... :)
In this case the OP lights from a short distance rendering the Speedlight overpowered in manual mode. The consumption of power by using fast shutterspeeds may take care of some of this problem but moving the flash back (its simply to close) and/or shoot it through some sort of diffusion or ND filter can deffinitely solve the issue.
Pictoraider
Joined May 2016
Post edited over 4 years ago by Pictoraider. (2 edits in all)
Feb 14, 2019 06:43 |  #14
soeren wrote in post #18810760 (external link)
If I understand well, Drisley looks to mix indoor available low ambient light and (manual) flash while using wide aperture such as f:1,8.
The tungsten lamp in my room delivers an ambient light such as I need to set 1600 ISO & 1 second at f:20 (= 100 ISO & 1/8 s at f:1,8) for correct ambient light exposure without flash.
How do you manage to carry out HSS with an 1:1 ambient/flash ratio when your camera max sync-X shutter speed is 1/250 s ?
Same question with an 2:1 ambient/flash ratio ?
NDAPhoto
Joined Jul 2015
Feb 14, 2019 07:32 |  #15
Set the Xpro-C and flash to a different channel and group.
4,408 views & 3 likes for this thread, 9 members have posted to it and it is followed by 4 members.
1459 guests, 136 members online
