Thread started 24 Jan 2019 (Thursday) 07:16
Battery anomaly
Frodge
Joined Nov 2012
Jan 24, 2019 07:16 |  #1
I have noticed this weird anomaly and was wondering if a couple of you guys can confirm this. This is on a 60D. I have an OEM, Watson, and Wasabi. I have noticed this in the past, but never thought about it. I took the oem out to charge and skipped the wasabi in. It showed 60%. I turned the camera off and turned it in and it showed 46%. I then was puzzled. I took the battery out and put it back in, showed 60%. With no shooting, I checked again later and it showed in the 46%. Do the wasabi batteries report incorrectly? My point is that it will initially register higher, and once in the camera for a bit, it will seem to lose some percentage points. But than weirdly, if it’s removed and put back in, it will report the higher value again. Can you folks check?
“It's kind of fun to do the impossible.” - Walt Disney.
Equipment: Tokina 12-24mm, Canon 40mm 2.8, Tamron 17-50 2.8 XR Di, Canon 18-55mm, Canon 50mm 1.8, Tamron 70-300VC / T3I and 60D
MakisM1
Gallery: 50 photos
Joined Dec 2011
Jan 24, 2019 09:33 |  #2
Frodge wrote in post #18797526 (external link)
I don't have a Wasabi. I have a couple of Sterlingteks which do not exhibit such behavior.
Have you tried to charge it at 100% and see what happens?
Also, run it from fully charged to fully discharged and see how many shots you get? (Rinse repeat with OEM for comparison).
Gerry
Left ­ Handed ­ Brisket
Gallery: 15 photos
Joined Jun 2011
Jan 24, 2019 10:00 |  #3
i've seen some things like that, but i just ignore it.
always have a back up.
gjl711
Jan 24, 2019 10:12 |  #4
I have seen that with Li Ion batteries in general, battery metering can be flaky. I think a lot of this is due to the physics of Li ion in that they are great at delivering a constant voltage for a long time and then they just die. As the batteries age and their internal resistance goes up, the battery meters have seem to have a harder time judging it's true capacity. For a really good read about the difficulty in metering a battery, check out this link (external link).
Not sure why, but call me JJ.
::Flickr:: (external link)
::Gear::
Trvlr323
Jan 24, 2019 10:14 |  #5
Left Handed Brisket wrote in post #18797598 (external link)
+1.
Sometimes not taking a photograph can be as problematic as taking one. - Alex Webb
Mike ­ Deep
Gallery: 95 photos
Post edited over 4 years ago by Mike Deep.
Jan 24, 2019 12:09 |  #6
Third party batteries (and batteries in general, I guess) get weird sometimes.
Something I've noticed is how a questionable battery will report a high or full charge right up until you stress it by increasing the current draw--for instance, by turning on live view. Then it flatlines and the camera quits.
mikedeep.com (external link) - rocket launch photography
John ­ from ­ PA
Joined May 2003
Post edited over 4 years ago by John from PA.
Jan 24, 2019 12:53 |  #7
Mike Deep wrote in post #18797688 (external link)
You start by stating a "questionable battery" so this may not apply, but it is relatively normal for most rechargeable batteries to have a characteristic where they reach a point of discharge, and then rapidly fail (not permanently) in the device. Note the image below, where at 20% charge the battery is going to fail rapidly. Sometimes turning on LiveView, which is a power hog, is just enough to push the battery over the edge in a short period of time. That's why it is always a good idea to carry at least one reliable battery with a good charge.
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2019/01/4/LQ_957622.jpg
Image hosted by forum (957622) © John from PA [SHARE LINK]
John ­ from ­ PA
Joined May 2003
Jan 24, 2019 13:34 |  #8
MakisM1 wrote in post #18797581 (external link)
That could be a lot of unnecessary shutter actuations. I would just suggest turning on the screen continuously and allowing the device to temporarily die. Then recharge, repeat the discharge cycle, then recharge and then check the performance. They say these batteries don't have a memory effect, but I have found the batteries get revived by a few full deep discharge/recharge cycles.
Frodge
Joined Nov 2012
Jan 24, 2019 13:37 |  #9
I agree with that graph John. I will also say that the OEM batteries seem to report proper percentage along the way. I’ve left oem batteries in the camera and the percentage drops at a known type of interval. Every aftermarket I have, none of them super old, seem to bounce back and forth and move all over the place.
Tom ­ Reichner
"That's what I do."
Gallery: 213 photos
Location: from Pennsylvania, USA, now in Washington state, USA, road trip back and forth a lot
Post edited over 4 years ago by Tom Reichner.
Jan 24, 2019 13:45 |  #10
I often get similar anomalies with the original Canon batteries. For example, with my 1D4 batteries, there are times when I look at the remaining capacity and it'll say, like, 78 percent. Then I'll take it out, put it on the original Canon charger, and the charger will blink once or twice, then the light stays on, indicating a full charge.
At other times, after shooting a lot in a short time, the camera will tell me that the battery is down to, say, 50 percent. Then after not using the camera for an hour or so, I'll check the battery again and it'll say it's at 60 or 70 percent.
Neither of the above scenarios are logical. What's up with the inaccurate reporting?
This upsets me, as I am one of those people who think that every single thing should be absolutely and completely accurate at all times.
Why don't battery capacity readouts provide us with absolute accuracy in all situations? This is important to me and I want future cameras and batteries to be precise and perfect in this regard.
John ­ from ­ PA
Joined May 2003
Jan 24, 2019 14:46 |  #11
Frodge wrote in post #18797751 (external link)
You and I bought our 60D's about the same time and I don't have any issues but I only have the OEM and (2) STK's. If they didn't labels, I'd be hard pressed to tell the difference based on behavior.
Frodge
Joined Nov 2012
Post edited over 4 years ago by Frodge.
Jan 24, 2019 14:50 as a reply to  @ John from PA's post |  #12
How do you like the 80d John? I still think the 60d works great. But the 80d has always been my next wanted acquired asset.
John ­ from ­ PA
Joined May 2003
Jan 24, 2019 14:57 |  #13
Tom Reichner wrote in post #18797762 (external link)
Don't let this upset you because it can be part of the normal chemical process that goes on in almost any battery, regardless of chemistry. Even with the plain Jane zinc/carbon battery from years ago, as it discharged, electrons flowed and there was a build up of hydrogen gas on the carbon rod. Take the battery down quite a bit, turn the device off and allow time for the hydrogen to dissipate, and the battery would appear to be improved when you turned the device back on. It might have a relatively short life however. So indications of charge can be quite erratic, especially in an example likes yours where you take the battery down to 50% and an hour later is reads 60 or 70%. Probably perfectly normal but note I say probably. There of course could be other issues.
TeamSpeed
01010100 01010011
Gallery: 116 photos
Joined May 2002
Post edited over 4 years ago by TeamSpeed.
Jan 24, 2019 15:17 as a reply to  @ Tom Reichner's post |  #14
Batteries can very quickly change their potential, temperature alone plays a big part. A battery in a bag that is first put into a camera could read one thing and in minutes read a different value. Also, different PCB design in these batteries may have different ways to measure capacity, thus why different manufactured batteries act differently. Battery behavior just isn't always consistent, as much as we feel they should be.
John ­ from ­ PA
Joined May 2003
Jan 24, 2019 17:39 |  #15
Frodge wrote in post #18797787 (external link)
Great camera! I still use the 60D, generally keeping a Sigma 17-70 mounted somewhat semi permanently.
1,650 views & 3 likes for this thread, 9 members have posted to it and it is followed by 5 members.
Battery anomaly
1294 guests, 136 members online
