Thread started 31 Jan 2019 (Thursday) 16:02
On/off switch
Frodge
Joined Nov 2012
Jan 31, 2019 16:02 |  #1
Do you folks keep your cameras on all the time or do you switch them off when down for the day? I’ve read that when you switch off it doesn’t actually cut the power. If that is the case, what is the point of the switch at all? Also, I have a classic car and it is recommended to use switches to keep the contacts from getting corroded. I was wondering wht the though was in this. Is it better to leave them on? If so, are you potentially making your switches get crappy from not being moved back and forth. I know this is true for old radios and volume knobs too.
“It's kind of fun to do the impossible.” - Walt Disney.
Equipment: Tokina 12-24mm, Canon 40mm 2.8, Tamron 17-50 2.8 XR Di, Canon 18-55mm, Canon 50mm 1.8, Tamron 70-300VC / T3I and 60D
gjl711
Jan 31, 2019 16:15 |  #2
For bodies that I do not use often, like my 7D, I switch it off but the bodies I use often or even weekly, I just leave on. Old radio tuner and volume knobs aren't really switches and work differently than a on/off switch.
Not sure why, but call me JJ.
::Flickr:: (external link)
::Gear::
John ­ from ­ PA
Joined May 2003
Jan 31, 2019 16:31 |  #3
I turn my bodies (60D & 80D) off and for a couple of reasons. I store in a backpack and if leave it on, any inadvertent pressure or contact with the shutter wakes the camera up. If this happens in the bag, I may find an unexpected dead battery. I also like that power cycling also does a sensor cleaning.
Frodge
Joined Nov 2012
Jan 31, 2019 16:35 |  #4
I like that it does a sensor clean too. You can do that through the menu system as well. I have always turned mine off when done.
Wilt
Feb 01, 2019 14:50 |  #5
Frodge wrote in post #18802218 (external link)
The modern camera battery now often maintains current in a capacitor to drive the camera's date & clock even when turned Off, unlike many earlier cameras which had button cells to drive the clock circultry. So the 'benefit' of turning Off the camera is to drop any current draw to a minimum (the clock) rather than always spending current by monitoring the shutter button to 'wake up'
Left ­ Handed ­ Brisket
Gallery: 15 photos
Joined Jun 2011
Feb 01, 2019 15:45 |  #6
it keeps it from accidentally being woken up from sleep which would drain your battery, especially depending on how your camera is set up. I often shoot tethered so i sometimes have it set to never go to sleep. I usually remember to change it back, but not always.
I generally switch it off, but if I am out shooting for a day or weekend (without tethering) often I don't switch it off. Not a big deal either way as long as it is set to sleep after a couple of minutes.
895 views & 1 like for this thread, 5 members have posted to it and it is followed by 3 members.
On/off switch
1294 guests, 135 members online
