Thread started 04 Feb 2019 (Monday) 03:19
Lens Strap. Anybody use?
fordmondeo
I was Soupdragon in a former life.
Feb 04, 2019 03:19 |  #1
Does anyone use the lens strap provided with the large canon tele lenses?
I found it gets in the way and am wondering how likely it is to damage the camera lens mount during normal hand held use.
My thanks in advance for any replies.
Vaginator9000
NullMember
Feb 04, 2019 03:27 |  #2
bannedPermanently
fordmondeo wrote in post #18804367 (external link)
I don't understand how a lens strap can damage the lens mount.
fordmondeo
Feb 04, 2019 03:55 |  #3
john crossley wrote in post #18804370 (external link)
Didn't word that very well did I.
I'm told that the weight of a 300mm 2.8 L can damage the camera mount if you carry the lens/camera combo using the camera strap.
Vaginator9000
Perfectly ­ Frank
I'm too sexy for my lens
Gallery: 147 photos
Feb 04, 2019 04:06 |  #4
fordmondeo wrote in post #18804385 (external link)
Never heard of that. No problem with my 300 f2.8
When you see my camera gear you'll think I'm a pro.
When you see my photos you'll know that I'm not.
My best aviation photos (external link)
My flickr albums (external link)
bildeb0rg
Gallery: 821 photos
Feb 04, 2019 04:37 |  #5
Any mechanical coupling can be stressed by repeated flexing, but I don't hing this is a particular issue re lens mounts. My 20 plus year old 300L is still fine and has NEVER fallen off my camera to date. Wish me luck guys...
fordmondeo
Feb 04, 2019 04:48 |  #6
I'm not very good at this whole typing thing.
I'm led to think the weight of the lens can damage the camera so, the the lens carries the camera as opposed to the camera carrying the lens.
Vaginator9000
NullMember
Feb 04, 2019 05:02 |  #7
bannedPermanently
fordmondeo wrote in post #18804408 (external link)
Letting the lens hang vertically from the camera body shouldn't put any undue strain on the lens mount as long as you take the weight of the lens with your left hand as you raise the camera back up to your eye.
If you are walking around with a big hefty lens it's best to hold it in the crook of your arm as if holding a baby.
fordmondeo
Feb 04, 2019 07:30 |  #8
john crossley wrote in post #18804411 (external link)
That's what I was hoping.
Thanks.
Vaginator9000
bpalermini
Gallery: 203 photos
Joined Mar 2011
Feb 04, 2019 09:41 |  #9
I always have the strap attached to my 400/2.8 and I used to always have the strap attached to my 300/2.8. I am confident of it to carry my lens, camera and monopod all mounted together when walking to my final destination. I have removable straps on my bodies so when I have them mounted on the big lens I don't have two straps to tangle. Anyway, I have never found that the strap on the lens got in the way.
Bob
R6II, R6, EF 16-35L II 2.8, EF 24-70L II 2.8, RF 50 1.8, EF 100L Macro 2.8, RF 70-200L 2.8, EF 100-400L II, EF 200-400L 4, EF 1.4xIII, EF 2xIII, 580EXII, YN560IV, RRS TVC23 + BH55, Fuji X-E2, Fuji X30, LRCC, PSCC
My Web Site (external link) | My Sports Portfolio (external link) | Instagram @bobpal
fordmondeo
Feb 04, 2019 10:08 |  #10
bpalermini wrote in post #18804486 (external link)
Perhaps I'm doing something wrong.
With the canon supplied lens strap fitted I find it snarls up on the tripod mount lock and drags itself across the top of the camera.
It also seems to get in the way of the shutter button and other controls on the camera top plate.
It's just as bad during hand held portrait orientation shots too.
With both the camera and the lens straps fitted the tangled mess that ensues drives me to distraction.
is it possible that just one lens lug is strong enough to carry the whole caboodle? If so, that may be an option as the case carrying strap has dog lead clips on it and can be fitted to the same side of the lens.
Vaginator9000
Trvlr323
Feb 04, 2019 10:18 |  #11
fordmondeo wrote in post #18804504 (external link)
I use both lens lugs for carrying a super telephoto. Like Bob I've never had an issue. I don't use the Canon supplied strap. Presently I use a Peak Design Slide and in the past I use a bandolier style strap from another company. I am unsure of your description regarding having both a camera and lens strap fitted. If you are using a strap attached to the lens why would you need one attached to the camera? I am also unsure of your description of the strap getting snarled on the mount lock and getting in the way of the shutter button. I can't really visualize how this might happen. Would you mind posting a picture of this scenario? Maybe we can get you sorted out better that way.
Sometimes not taking a photograph can be as problematic as taking one. - Alex Webb
NullMember
Feb 04, 2019 10:44 |  #12
bannedPermanently
Surely if the lens is mounted on a tripod then the strap will hang down below the lens and in front of the the tripod. I don't see how it can interfere with the top of the camera.
fordmondeo
Feb 04, 2019 11:15 |  #13
john crossley wrote in post #18804531 (external link)
The lens is not mounted on a tripod.
With the lens facing downwards and with some tension on the strap, the strap interferes with with tripod mount locking knob and the mode dial on the left side. The strap, under the same conditions, abrades the camera top plate on the front right side.
I have both the camera and neck strap fitted as this is what the canon documentation describes, well, it does not say otherwise at least.
I'd like to think, as you suggest, the camera body (5D4) when facing downwards is sufficiently robust to support the weight of the lens without detriment to the lens mount/casting/body assembly.
Vaginator9000
Perfectly ­ Frank
Gallery: 147 photos
Feb 04, 2019 11:46 |  #14
I have the 1DMKIV and 300 f2.8 II. I don't use any type of strap to carry. I use the Cotton Carrier vest, the best method I've found to carry my large and heavy gear.
I screw the Cotton Carrier hub onto the tripod ring foot, that way the camera/lens is being carried by the tripod foot. I also use a tether as safety in case the camera should slip out of my hands.
https://www.cottoncarr​ier.com …ducts/g3-camera-harness-1 (external link)
CyberDyneSystems
Admin (type T-2000)
Gallery: 193 photos
Joined Apr 2003
Post edited over 4 years ago by CyberDyneSystems.
Feb 04, 2019 13:51 |  #15
I use the lens strap on my 500mm always.
When hand holding, I use both it and the one on my EOS body.
I don't use the Canon one included, I use an Optech with long straps.
CDS' HOT LINKS
3,693 views & 11 likes for this thread, 9 members have posted to it and it is followed by 3 members.
1455 guests, 128 members online
