FORUMS General Gear Talk Data Storage, Memory Cards & Backup
Thread started 05 Feb 2019 (Tuesday) 09:30
CF card is too slow for my Canon EOS-7D to record 1080 video
BridgeBGB
Joined Dec 2018
Feb 05, 2019 09:30 |  #1
My current CF card is too slow for my Canon EOS-7D to record 1080 videos. The buffer overflows in about 3 seconds. What speed do I need ? Any recommendations ?
Many Thanks
John ­ from ­ PA
Joined May 2003
Post edited over 4 years ago by John from PA.
Feb 05, 2019 10:12 |  #2
That is a bit surprising. Can you supply the exact details of the CF card you are currently using?
Good discussion on the requirements at https://www.dpreview.c​om/forums/thread/30144​06 (external link). Additional info in the manual (see http://gdlp01.c-wss.com …02580/02/eos7d-im2-en.pdf (external link)) at pages 156 to 159.
BridgeBGB
Joined Dec 2018
Feb 05, 2019 15:45 as a reply to  @ John from PA's post |  #3
It's a old CF (came with the camera - used so I don't know). I suspect the card itself could be near its end of life.
John ­ from ­ PA
Joined May 2003
Post edited over 4 years ago by John from PA. (5 edits in all)
Feb 05, 2019 16:15 |  #4
BridgeBGB wrote in post #18805508 (external link)
Can the 7D use an SD? If it can and with the improved speeds of SD type cards I'd suggest you get something like the Sandisk Extreme Plus in 90 mb/sec or faster. You can get a 64gb fr $29 (normally $45) at Best Buy. See https://www.bestbuy.co​m …romo/sandisk-extreme-plus (external link).
Edit, apparently the 7D is CF only so suggest the card at https://www.bestbuy.co​m …d/2037002.p?sku​Id=2037002 (external link)
cristphoto
Post edited over 4 years ago by cristphoto. (2 edits in all)
Feb 05, 2019 17:14 |  #5
The owners manual for my 5D4 says use at least 60 mb/sec for 1080 movies. Cards are pretty cheap - get a good fast one. Plus it's always a good idea to have more than one card.
1DX MK II, 5D MKIV x2, 24L II, 35L II, 50L, 85LIS, 100LIS Macro, 135L, 16-35LIS, 24-105LIS II, 70-200LIS, 100-400LIS II
CyberDyneSystems
Admin (type T-2000)
Gallery: 193 photos
Joined Apr 2003
Post edited over 4 years ago by CyberDyneSystems. (3 edits in all)
Feb 05, 2019 17:29 |  #6
John from PA wrote in post #18805528 (external link)
Also, even much newer bodies like the 5D3 were terribly slow with SD, regardless of the cards speed, it lacked the latest SD compatibility.
With CF cards, one can get up to 5 times faster results on bodies of this generation.
I'd recommend a Sandisk CF Extreme or Extreme Pro. The Ultra Might do it. (rated @ 50MBs vs. 120 and 160)
CDS' HOT LINKS
Butts
I coulda shoulda woulda
Feb 05, 2019 18:07 |  #7
CF II, UDMA 7 and you will have no issues.
776 views & 1 like for this thread, 5 members have posted to it and it is followed by 3 members.
1056 guests, 117 members online
