Is there a way to make the slider buttons on the right bigger? (See attached.) Drives me nuts that they are so small!
Thanks-
tspencer1 Member More info Post edited over 4 years ago by tspencer1. | Feb 22, 2019 10:44 | #1 Is there a way to make the slider buttons on the right bigger? (See attached.) Drives me nuts that they are so small! Image hosted by forum (962681) © tspencer1 [SHARE LINK] THIS IS A LOW QUALITY PREVIEW. Please log in to see the good quality stuff.
kirkt Cream of the Crop More info Post edited over 4 years ago by kirkt. (3 edits in all) | Feb 22, 2019 11:16 | #2 Nope, but there are keyboard shortcuts that might make getting to your desired adjustment value easier. Kirk
Thanks Kirk - will check those out. Clarification - not my shot - found on the Adobe forums - should have made that clear!
kirkt Cream of the Crop More info Post edited over 4 years ago by kirkt. | To get nit picky - the forum does not allow direct posting of images that are not yours - you can link to them, but not post them directly. Just a heads up. Kirk
Appreciate the heads-up on that. I just fixed it so only the develop module shows - thanks.
Bcaps I was a little buzzed when I took this More info | Feb 22, 2019 12:11 | #6 I rarely use the actual slider buttons. Instead, you can hover the mouse over the number on the right and it turns into a slider which is bigger than the slider on the line. Below, for the highlights, I have my mouse on the highlights number on the right (the cursor doesn't show up in the screenshot). You can see how the color changes around the "0", that is how big the slider is. You just drag right/left to change the value. Image hosted by forum (962682) © Bcaps [SHARE LINK] THIS IS A LOW QUALITY PREVIEW. Please log in to see the good quality stuff. - Dave | flickr
Bcaps - thanks! That will make a huge difference in workflow!
| Latest registered member is semonsters 1061 guests, 101 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
