Thread started 12 Mar 2019 (Tuesday) 10:46
Looking for filter case
CallumRD1
Gallery: 22 photos
Joined Sep 2012
Mar 12, 2019 10:46 |  #1
I'm looking for some kind of hard case for 2-4 77mm round filters. (2 being the minimum for a 10 stop ND and a CPL.) I'll be hiking and taking landscape photos so I want something with some durability so that they don't get broken if pressed on by something in my pack. A lower profile would be better too, to save space. Does anyone have any recommendations for me?
TeamSpeed
01010100 01010011
Gallery: 116 photos
Joined May 2002
Post edited over 4 years ago by TeamSpeed. (6 edits in all)
Mar 12, 2019 11:14 |  #2
How about a soft pouch to hold them and then put the pouch into a pelican case?
https://www.thepelican​store.com …o/pelican-1060-micro-case (external link)
https://www.amazon.com …ilter-Pouch/dp/B000F4S9EU (external link)
I have the tiffen pouch and it is handy, so I would think all I would need is a robust case to put that into.
Lifetime warranty on the pelican too. If you didn't want the tiffen pouch, you can buy pluck foam for the pelican case, and you could create filter pockets within that pluck foam. The foam block adds $6 to the case price. The case is water resistant, so you may be able to fit other things in it too, or go to a different size. The G40 looks interesting to me personally.
https://www.thepelican​store.com/cases/micro (external link)
If waterproofing isn't necessary, nor a lifetime warranty and such ruggedness, then something like a hard headphone case might work, just keep filters within soft envelopes so they are separated from each other.
https://www.amazon.com …&qid=1552407848​&s=gateway (external link)
John ­ from ­ PA
Joined May 2003
Mar 12, 2019 15:03 |  #3
Many years ago 3M packaged electrical tape in a round plastic box that measured 3.25 inches on the inside. I have several and they work fine for two and sometimes three 77mm filters somewhat depending on the physical characteristics of the filter; thickness and outside diameter. Unfortunately tape isn’t packaged that way anymore but perhaps you are a pack rat like me and have some around.
I would also suggest you take a trip to a local Michael's or Hobby Lobby craft store and see what they might have. I know my wife has something in the way of a rigid hinged plastic box, probably from Michael’s and it measures 3.5 x 3.5 x 1. I think it is for storeage of beads.
If you have a “The Container Store” location near you also give them a check.
Tip for shopping these craft stores; always ask for help! They are huge but if you give a store employee an idea of what you want, they know best of all the possibilities.
TeamSpeed
01010100 01010011
Gallery: 116 photos
Joined May 2002
Mar 12, 2019 15:47 |  #4
Could try using 3.5" floppy cases, they are still around.
https://www.shopqvs.co​m …01-CD/DVD/Disk-Cases.aspx (external link)
https://www.amazon.com …id=pla-365263519366&psc=1 (external link)
John ­ from ­ PA
Joined May 2003
Mar 13, 2019 05:07 |  #5
Check the Ruggard offering at B&H ($10). See https://www.bhphotovid​eo.com …ket_filter_pouc​h_for.html (external link).
Note that the pouch when open is said to measure 4.5 x 17.5" when opened and then folds to a compact, 4.5 x 4.5".
The version made by Sensei seems to be identical at $7. See https://www.bhphotovid​eo.com …ilter_pouch_3_p​ocket.html (external link)
TeamSpeed
01010100 01010011
Gallery: 116 photos
Joined May 2002
Mar 13, 2019 05:19 |  #6
So based on the OP, how hard or rigid must the storage unit be for the filters? I presume hard enough to prevent any kind of flexing force against one side of the filter. Without any continued feedback, all kinds of ideas will be suggested. :(
Sibil
Mar 13, 2019 07:01 |  #7
I have many OEM filter cases which I use in case I need better protection than aftermarket soft cases, in situations similar to OP's.
CallumRD1
Gallery: 22 photos
Joined Sep 2012
Mar 13, 2019 11:19 |  #8
Thanks for the suggestions everyone. I'm looking for something fairly rigid and protective, but I don't want anything nearly as bulky or heavy as a pelican case. The suggestion that seems best so far is the electrical tape box. I happen to have a box from a roll of Scotch Super 88 in front of me and it has an internal width of 87mm, which isn't too bad. It's 20mm deep so would fit several filters. This would be sufficiently rigid for me and pleasantly light (16 g) and compact, which is good for backpacking. I'd need to make a set of thin foam spacers to keep the filters separated. The issue is that it's a little less than ideal if I wanted to take the bottom filter out of the case. It would be easy to accidentally drop a bunch of filters, especially with cold and numb fingers.
For reference, I'm currently using a 110 x 110 x 35 mm soft folding filter wallet that holds 3 filters. I don't like the lack of protection it provides and I especially dislike how easily the filters slide out. Last year my brother destroyed a 10 stop ND filter when it slid out of the case while he was unfolding it. (It's currently holding a 10 stop ND, 3 stop ND, and CPL.)
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2019/03/2/LQ_966195.jpg
Image hosted by forum (966195) © CallumRD1 [SHARE LINK]
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2019/03/2/LQ_966196.jpg
Image hosted by forum (966196) © CallumRD1 [SHARE LINK]
brucea
Gallery: 28 photos
Joined Oct 2004
Mar 13, 2019 11:28 |  #9
Don't the filters come in little plastic boxes? Why not just use what came with the filters?
John ­ from ­ PA
Joined May 2003
Mar 17, 2019 13:46 |  #10
I happened to be in a Christmas Tree shop this morning and in their container section they had a package of (3) 8 ounze rigid and round plastic containers. I didn't have anything to measure them with but they were about 3-1/4 iches. Each contaiiner was about 1 inch high.
$2 for the set of three.
P ­ Taylor
Joined Jan 2019
Apr 14, 2019 14:53 |  #11
Have you looked into stacking caps. They protect your filters and add very little to there length.
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2019/04/2/LQ_971987.jpg
Image hosted by forum (971987) © P Taylor [SHARE LINK]
nordlysBW
Apr 24, 2019 16:21 |  #12
I also use stack caps. Compact and sturdy.
2,259 views & 0 likes for this thread, 7 members have posted to it.
1062 guests, 115 members online
