FORUMS General Gear Talk Tripods, Monopods & Other Camera Support
Thread started 16 Mar 2019 (Saturday) 20:12
Using loctite on camera plate?
kaitlyn2004
Mar 16, 2019 20:12 |  #1
I have an L bracket almost permanently on my 5D. Then I also attached my peak design capture clip to the L bracket (proprietary) for using with my backpack strap. Although the peak design plate has a bit of rubber on it, I find it hard and more slippery than grippy, plus the L bracket has a more hollow design so there isn't too much actually holding/locking the peak design to the L bracket apart from the screw itself.
I was thinking of adding loctite to the screw - would it make enough of a difference? I have never used it and don't know how much twisting force it would hold? I think blue is the least permanent solution, but is it still a good hold over nothing? Should I try something else?
My Landscape Photography Videos (external link)
My Instagram (external link)
Left ­ Handed ­ Brisket
Gallery: 15 photos
Joined Jun 2011
Mar 16, 2019 20:19 |  #2
From what you seem to be describing, it isn't the fact that the screw is coming loose, but that there isn't friction between the two pieces of metal. Thread locker would do no good.
You might take a flat file or even a piece of coarse sandpaper to the point where the plate and L bracket meet. I suspect just hitting one would do it, but you might need to hit both, gently.
Perfectly ­ Frank
I'm too sexy for my lens
Gallery: 147 photos
Mar 17, 2019 01:31 |  #3
I have a Cotton Carrier camera vest. It uses a metal hub that screws to the tripod mount on the bottom of the camera.
To prevent the hub from coming loose, I use a drop or two of Loctite 242 on the screw threads. It is blue color and removable. Works great and never had a problem with it.
Just be sure it says removable. Here's what I use:
https://www.homedepot.​com …Blue-242-209728/100371826 (external link)
When you see my camera gear you'll think I'm a pro.
When you see my photos you'll know that I'm not.
My best aviation photos (external link)
My flickr albums (external link)
John ­ from ­ PA
Joined May 2003
Mar 17, 2019 07:15 |  #4
It isn't clear in my my mind what you are describing but if the screw is what imposes the clamping force that creates the friction (as someone has mentioned) then the clamping force needs to be increased or the surface roughened (also as someone mentioned). If you feel that tightening the screw helps, then initially just try some clear nail polish on the threads to "lock" them. If the desired effect is obtained, then go to the blue Loctite (#242) but use it sparingly. On small thread sizes it is quite strong. You can get it at places like Home Depot, Lowes and most hardware stores. It's around $5 to $6 so do the nail polish test first.
peter_n
Mar 17, 2019 09:04 |  #5
WRT thread locker I'm absolutely with John above. Use use clear nail polish first, then blue Loctite, then red Loctite if you must. The red normally requires heat to loosen. I've never used red but I use bSi 102 Insta-Cure for an absolutely permanent lock until the end of time. It's very thin and I'm extremely careful and wear gloves when I'm using it. I've had a tiny bottle for years and it still works great. I'm scared of it though to be honest.
With all of these thread lockers you just need a dab. Drop the dab onto a thread very near to the top end of the bolt you're screwing into the socket. The little dab is worked into the threads below it when you turn the bolt. Be conservative about allowing it to set. Blue Loctite can be broken with a sudden impulsive anti-clockwise wrench of one of the connected parts.
~Peter
Perfectly ­ Frank
Gallery: 147 photos
Mar 17, 2019 11:06 |  #6
peter_n wrote in post #18830186 (external link)
NO!
Don't use red loctite that requires heat to remove. You never used red but advise the OP to use it? Bad idea.
We use the red type at work and it can be very difficult to remove screws that has it.
Use the 242 type as in the link I provided. Nail polish is for nails, loctite is for threaded fasteners.
kaitlyn2004
Mar 17, 2019 11:39 |  #7
I think I'll give the blue loctite a try, figring worst case it simply doesn't work...
Assuming it does NOT work, could it actually CAUSE problems i.e. prevent screw from even going in properly after removal?
John ­ from ­ PA
Joined May 2003
Post edited over 4 years ago by John from PA. (3 edits in all)
Mar 17, 2019 13:51 |  #8
kaitlyn2004 wrote in post #18830263 (external link)
The issue is it might just work too well! The product is designed to lock threads to an extent that tools are required to loosen them. Blue is relatively small hand type tools, somewhat dependent on thread size. Red is near permanent often requiring (as someone mentioned) heat. There can be some removal issues with blue hence the reason why I suggested nail polish as a test. That will give you the absolute least potential issues and if it works and you are happy then move to the blue Loctite. This what the manufacturer says about Loctite 242. Note they specifically say it is for fasterers larger than 1/4 inch and do not use on most plastics.
Recommended For
Use on metal fasteners 1/4” (6 mm) to 3/4” (19 mm) in diameter such as bolts on small engines, swing sets and furniture
Not Recommended For
Use on plastic parts, particularly thermoplastic materials where stress cracking of the plastic could result
peter_n
Mar 17, 2019 19:39 |  #9
Perfectly Frank wrote in post #18830248 (external link)
NO!
I did not advise the OP to use red Loctite. I wrote: Use use clear nail polish first, then blue Loctite, then red Loctite if you must.
The meaning of "if you must" is when you think that you probably can't stop a person doing something that you think is wrong.
~Peter
Perfectly ­ Frank
Gallery: 147 photos
Mar 17, 2019 23:22 |  #10
peter_n wrote in post #18830472 (external link)
No problem.
I use blue loctite242 on the screw that goes into the tripod thread on the bottom of my camera (1D4 & 80D). Never had a problem removing the screw.
Choderboy
I like a long knob
Gallery: 185 photos
Mar 18, 2019 04:15 |  #11
Why not use red? It's 2 pieces of metal and a 'rubber pad'. The rubber pad is on the cheapest part, the plate and that's the only part at risk of damage from heat.
Almost everyone has a stove. If you need to remove, throw the bracket with plate attached in some boiling water for 2 minutes.
Even a hair dryer will provide enough heat.
Using red on the tripod socket of a camera body would obviously be risky as need for heat could damage the camera.
Dave
Image editing OK
John ­ from ­ PA
Joined May 2003
Post edited over 4 years ago by John from PA. (2 edits in all)
Mar 18, 2019 05:57 |  #12
Choderboy wrote in post #18830638 (external link)
From the manufacturer Henkels/Loctite:
How to Remove Red Threadlocker
Andy Scott February 13, 2014
It can be difficult removing Loctite® red threadlocker, and it’s a common vehicle maintenance question. While the strength of our red threadlockers is formidable, and meant to be a permanent assembly method – don’t believe the myths… red threadlocker can be disassembled with the right technique.
When disassembling red threadlocker the process is a little different than for other threadlockers. The key is to apply localized heat greater than 550° F. Then, once the threaded assembly is hot, the bolt can be unthreaded. Without applying heat to the assembly, it’s likely that over time, a bolt would break before coming loose.
Now, I'll say, as a mechanical engineer with 45 years of experience, that a "formidable" bond is obtained when the threads are clean and properly torqued; i. e., ideal conditions. So, if we positively know the threads have sunscreen, peanut butter or whatever on them go ahead and use red. But if we also have a person using the product that reads and follows the directions, the likelihood is high that significant damage can occur.
I will say that you have no dog in the fight, nor do I, so if the OP uses 242 "blue" or 222 "red" and screws up the tripod for whatever reason, he/she can't come back to either of us. However, should he/she "sneak" up on things, using what camera technicians used 50 years ago (nail polish), they can always do it over if it doesn't hold.
Perfectly ­ Frank
Gallery: 147 photos
Mar 18, 2019 06:11 |  #13
I don't know of a 550 degree hair dryer. ;-)a
1,736 views & 4 likes for this thread, 6 members have posted to it and it is followed by 2 members.
1507 guests, 135 members online
