Thread started 18 Mar 2019 (Monday) 06:14
Should a lens be stopped down before storing upright or horizontal?
vision35
Gallery: 26 photos
Post edited over 3 years ago by vision35. (5 edits in all)
Mar 18, 2019 06:14 |  #1
Having purchased a few L lenses costing $1000 - $1400 I would like some opinions of proper lens storage.
Is it better to store the lens upright or horizontal?
Lens cap facing up or down?
Update: I will personally go with horizontal in a hard shell waterproof case. I really don't want to carry a heavy hard case measuring 10" or 12" deep. Maybe I will make a climate controlled storage cabinet. lol
I'll take a look at the packaging and a you tube Canon lens unpacking video and see how they arrive packaged from the factory. That should be good enough in theory.
Should the lens be stopped down before storage? Someone implied it may be better for the iris and springs.
I don't know if stopping down the lens prior to storing is good or bad for the lubricants. Will the lubricants run or dry up?
I recall many years ago seeing some FD lenses with an internal gooey mess.
bildeb0rg
Gallery: 821 photos
Post edited over 4 years ago by bildeb0rg.
Mar 18, 2019 06:17 |  #2
Won't make any difference unless you are talking years.
As an aside, I would advocate using, not storing lenses. Much more fun.
CyberDyneSystems
Admin (type T-2000)
Gallery: 193 photos
Joined Apr 2003
Mar 18, 2019 11:45 |  #3
vision35 wrote in post #18830666 (external link)
This part is out of your control on a Canon "L" (or any EF) lens, so don't even consider it.
The lens is ALWAYS wide open, when stored, or on your camera, regardless of where your aperture is set. Springs hold it wide open, and can't be set otherwise.
Only when you release a shutter does the motor stop the lens down for the fraction second required, then it springs back wide open.
I also don;t imagine upright or horizontal matters. Canon's big lenses come with storage cases that hold them horizontal, but the smaller lenses come with pouches that hold them upright. This says to me that Canon doesn't care.
CDS' HOT LINKS
gjl711
Mar 18, 2019 12:13 |  #4
CyberDyneSystems wrote in post #18830805 (external link)
The lens is ALWAYS wide open, when stored, or on your camera, regardless of where your aperture is set. Springs hold it wide open, and can't be set otherwise....
Actually, there is a way you can close the aperture to whatever f-stop you want. Reverse lens macro shooters will mount the reversed lens, set the aperture to their desired aperture, press the DOF preview button and then dismount the lens with the DOF preview button pressed.. The lens will stay at the previewed aperture.
I am not advocating doing so as I really don't think it matters how the lens is stored, but it is possible. For storing a lens, I believe it's more important to make sure both front and rear caps are on , and the lens is stores in a lens bag or lens case. For lenses that came bag-less, I place them in a Ziploc. This helps keep dust off the lens.
Not sure why, but call me JJ.
::Flickr:: (external link)
::Gear::
DreDaze
Gallery: 49 photos
Mar 20, 2019 14:55 |  #5
just put the caps on, and store it however you want...
Andre or Dre
gear list
Instagram (external link)
RDKirk
Adorama says I'm "packed."
Joined May 2004
Post edited over 4 years ago by RDKirk.
Mar 20, 2019 15:17 |  #6
Back in the days of fully mechanical cameras with auto-aperture lenses, you could usually release the aperture off-camera to relax the springs.
However, the fact is that springs do not take a "set." That's a myth. So it never mattered.
Also back in those days it was possible for oil-based lubricants to harden if left unattended for years. But it didn't matter whether the aperture was left opened or closed--it was going to harden either way. More of a likely problem was leaving the lens in an area of really high temperatures, like on the car seat in the summer. That really did hold the possibility of evaporating lubrication within the lens to be deposited on the interior lens elements.
As far as I can tell, modern lenses use low-friction blade coatings that don't need lubrication.
CyberDyneSystems
Admin (type T-2000)
Gallery: 193 photos
Joined Apr 2003
Post edited over 4 years ago by CyberDyneSystems. (4 edits in all)
Mar 20, 2019 15:48 as a reply to  @ gjl711's post |  #7
EDIT: Well, I'll be damned,.
Learn something new every day.
CDS' HOT LINKS
chuckmiller
Gallery: 65 photos
Joined May 2012
Mar 30, 2019 14:08 |  #8
If springs hold the blades open I can't see where it would be beneficial to pull on them and hold them in a well stressed state. Yes I understand that it is cycles of movement that causes wear on a spring but I have also seen springs that were stretched and left for a long period and then would not recover. You be the judge.
Retired from Fire/Rescue with 30 years on the job - January 2019
Left ­ Handed ­ Brisket
Gallery: 15 photos
Joined Jun 2011
Mar 30, 2019 15:07 |  #9
I store all my lenses diagonally at 37.5 degrees and rotate them every third lunar cycle on the first quarter of a waxing moon.
But really though, this thought does pop into my mind from time to time when throwing lenses in a bag or something. But then I realize it's probably a silly thought and go with convenient and random placement.
Tom ­ Reichner
"That's what I do."
Gallery: 213 photos
Location: from Pennsylvania, USA, now in Washington state, USA, road trip back and forth a lot
Mar 30, 2019 15:31 |  #10
Having a few L lenses costing $1000 - $1400
I have L lenses costing from $900 to $7,800.
My opinions about lens storage? . Hmmmm.
Well, right now my 400 f2.8 is in the back seat of my car, attached to a camera body. . Not in a case or anything, just laying on the seat on top of some stuff and under some other stuff.
There's lots of misc camping gear and so forth in that backseat, so the lens and camera just kinda ends up wherever it got put when it was used last. . If I used it real recently, then it goes on top of the camping stuff and the extra clothes and folding chair. . If I haven't used it for a few days, then the extra clothes and the folding chair and stuff end up getting used and put back on top of the lens & camera. . My backseat is kinda like a geological dig - you can tell what has happened most recently by what is on top, in the middle, and on the bottom, of the layers of gear and whatnot.
I almost always leave the lenses and camera gear in the backseat of my car. . Summer. . Winter. . Spring and Fall. . At home. . Away on trips. . I really don't see any reason to carry my gear inside when all I'm going to do is carry it back out to the car at some point. . Why not just leave it in the car where I'll need it next? . Same with the camping gear, blinds, tools, extra clothes, chest waders, boots, camouflage, snacks, drinks, etc. . I just leave it all in the car all the time and then I don't have to bother packing anything when I go somewhere to do something.
Just however they end up. . Doesn't matter. . Not worth thinking about.
Lens cap? . I don't usually bother with lens caps. . No need to really. . The front elements seldom get scratched, and when they do, the little scratches don't affect the lens' performance at all. . Caps just aint worth hassling with.
There's no ned to consider any of this. Just put 'em wherever it's easiest and where they won't fall on anything hard, if jostled. . L lenses are really tough and you don't have to baby them or give any special attention to how they are stored or treated. Ever.
ed ­ rader
"I am not the final word"
Mar 30, 2019 15:38 |  #11
I swaddle mine in bubble wrap and then hermetically seal in a scaled down model of the great pyramid of Giza  :p
5D4 x2, 16-35L F4 IS, 24-70L II, 70-200L F4 IS II, 100-400L II, 14L II, sigma 15 FE, sigma 28 f1.4 art, tc 1.4 III, 430exII, gitzo 3542L + markins Q20, gitzo GT 1545T + markins Q3T, gitzo GM4562
RDKirk
Joined May 2004
Mar 30, 2019 16:26 |  #12
chuckmiller wrote in post #18837548 (external link)
Those must have been springs stretched beyond their design specification. That doesn't happen to a spring that is used within its design spec, whether compressed or stretched. That's a function of the fatigue capability of the metal.
ozziepuppy
Gallery: 203 photos
Mar 30, 2019 17:43 as a reply to  @ RDKirk's post |  #13
Left Handed Brisket wrote in post #18837570 (external link)
ed rader wrote in post #18837581 (external link)
Wow, I do both of these (depends on my mood). I didn't realize I wasn't the only one. #kindredspirits
Marci
Constructive criticism always appreciated.
Gear
Pre-2018 Feedback :)
CyberDyneSystems
Admin (type T-2000)
Gallery: 193 photos
Joined Apr 2003
Mar 30, 2019 20:38 |  #14
I let mine age in an oak barrel for 16 years. the images I get are smoother, more full bodied with a distinct peaty flavor.
CDS' HOT LINKS
crofter
Joined Aug 2011
Post edited over 4 years ago by crofter. (3 edits in all)
Mar 31, 2019 07:34 |  #15
Wise move with the pyramid,It's a well known fact that razor blades stay sharp if kept in a pyramid,I've no reason to believe that lenses would not similarly benefit,in fact I'm going to start wearing a pyramid hat to keep my wits sharp.
http://www.flickr.com/​photos/70718847@N02/ (external link)
4,482 views & 19 likes for this thread, 13 members have posted to it and it is followed by 9 members.
1504 guests, 130 members online
