I am just curious if I could possibly print on a 140lb piece of watercolor paper with a Canon Pro-100.
Thanks!
Mar 22, 2019 21:59 | #1 I am just curious if I could possibly print on a 140lb piece of watercolor paper with a Canon Pro-100.
Mar 23, 2019 18:27 | #2 I'm not certain about English paper weights because different nominal weights are used for different purposes. That is, 140 pounds can mean different things. If you can find the weight in metric (gsm, grams per square meter), the answer would be clearer. SOME papers labeled as 140 pounds are 255 gsm. When I had a Pro-100, I routinely printed with heavier papers, usually 300 gsm, using manual feed. Check out my photos at http://dkoretz.smugmug.com
LeftHandedBrisket Combating camera shame since 1977... More info Post edited over 4 years ago by Left Handed Brisket. (2 edits in all) | Mar 23, 2019 19:22 | #3 Yup, the American way of measuring paper weights is backward AF. PSA: The above post may contain sarcasm, reply at your own risk | Not in gear database: Auto Sears 50mm 2.0 / 3x CL-360, Nikon SB-28, SunPak auto 322 D, Minolta 20
JohnfromPA Cream of the Crop 11,258 posts Likes: 1527 Joined May 2003 Location: Southeast Pennsylvania More info | Mar 24, 2019 10:55 | #4 Good conversion chart at http://www.papermartinc.com/wp-content/uploads/gsm2.pdf
BigAl007 Cream of the Crop 8,120 posts Gallery: 556 photos Best ofs: 1 Likes: 1682 Joined Dec 2010 Location: Repps cum Bastwick, Gt Yarmouth, Norfolk, UK. More info | Mar 28, 2019 03:43 | #5 Not your specific printer, but I do regularly print to a cheap 300gsm water colour paper with my Pixma MG5150. The results are really good. Non experts have thought my images to be watercolour. I use Canon PT2 and quality level 1 on the printer end from Lr.
| Latest registered member is semonsters 1531 guests, 130 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
