Thread started 29 Mar 2019 (Friday) 19:58
Camera Won't Turn Off!
Clyde29
Joined Mar 2019
Mar 29, 2019 19:58 |  #1
I have a Rebel EOS T2i. And I love it. It's been good to me.
Recently the camera won't shut off when switching the power switch. Is this a known problem?
Interestingly enough it will turn off when the battery hatch is opened (even if the battery is still in the camera)
Here is a video of the issue:
https://vimeo.com/3273​97219 (external link)
John ­ from ­ PA
Joined May 2003
Post edited over 4 years ago by John from PA.
Mar 29, 2019 20:19 |  #2
Well that is something new and different! Not sure what might work as seems to be very rare. Can’t find any other mention on the web. I think I would reflash the firmware as a starter. Doing that has fixed many strange issue in the past with several model cameras. Check here https://www.usa.canon.​com …subtab=download​s-firmware (external link) for the download and instructions.
On the battery cover, there is a very small switch in the cover that detects the dorr is open and that is intended to shut the camera down. What you are getting, with respect to the door, is proper behavior.
davesrose
Title Fairy still hasn't visited me!
Post edited over 4 years ago by davesrose.
Mar 29, 2019 20:55 |  #3
Yeah, resets are always the best first go to trouble shooting steps. I'd probably also try removing the main battery. I suspect the T2i has a watch battery too (newest Canon models no longer have). I'd remove all batteries and let it sit overnight (to be sure it's fully discharged). Then try putting the batteries back. It can help clear a possible error that's keeping the camera on.
Canon 5D mk IV
EF 135mm 2.0L, EF 70-200mm 2.8L IS II, EF 24-70 2.8L II, EF 50mm 1.4, EF 100mm 2.8L Macro, EF 16-35mm 4L IS, Sigma 150-600mm C, 580EX, 600EX-RT, MeFoto Globetrotter tripod, grips, Black Rapid RS-7, CAMS plate and strap system, Lowepro Flipside 500 AW, and a few other things...
smugmug (external link)
Dan ­ Marchant
Gallery: 19 photos
Joined Oct 2011
Mar 30, 2019 00:16 |  #4
Given that it shuts off normally when the battery cover is opened (it is designed to do that) it would seem that the likely problem is a faulty on/off switch.
Try doing the above suggestions (reset/firmware) and also test with/without lens (faulty/dirty connection might cause problem. If none of that helps then probably needs a repair/new switch.
Dan Marchant
Intheswamp
Endeavor to Persevere
Gallery: 89 photos
Joined Sep 2013
Mar 30, 2019 07:08 |  #5
I did a little searching (I've got a T2i, also, and you never know) and came up with a dearth of information regarding your problem. After a couple of pages of searching the only things I had come up with was that the Long Exposure Noise Reduction might cause the problem and a vague mention of sensor cleaning possibly being associated with the problem.
Also, have you ever used Magic Lantern with your T2i?
Best wishes,
Ed
The poorest of the poor. A country of children taking care of children: https://handsofloveusa​.org/ (external link)
My little weather page: www.beeweather.com (external link)
Clyde29
Joined Mar 2019
Mar 30, 2019 07:33 |  #6
Thanks for all the support! Sounds like I have a lot of things to try!
@inthewamp I have not used magi lantern
Clyde29
Joined Mar 2019
Mar 31, 2019 07:40 |  #7
Please don't laugh at me too hard... Is there a way to update the firmware without an SD card reader?
And, do yall know of a supplier for aftermarket On/Off Switches and the sort for cameras?
Dan ­ Marchant
Gallery: 19 photos
Joined Oct 2011
Post edited over 4 years ago by Dan Marchant.
Mar 31, 2019 08:24 as a reply to  @ Clyde29's post |  #8
deleted - reason - talking out my b&tt
Dan Marchant
crofter
Joined Aug 2011
Mar 31, 2019 08:44 |  #9
Clyde29 wrote in post #18837869 (external link)
Plug your camera into your computer and use Eos utility to do the update.
http://www.flickr.com/​photos/70718847@N02/ (external link)
Intheswamp
Gallery: 89 photos
Joined Sep 2013
Mar 31, 2019 09:16 as a reply to  @ Clyde29's post |  #10
Clyde29, I would think that for a part like that you would need to go to Canon or either find a junked out camera to rob one from. The bigger problem (for me) would be to figure out how to remove the old one and replace it. Does it have wire leads? Is it surface mounted to a circuit board? How do you get to it? Etc.,...
These articles might be interesting to you...
https://www.ifixit.com …+Casing+Replace​ment/32829 (external link) https://www.ifixit.com …p+Cover+Replace​ment/15005 (external link)
Does the camera function normally (other than not turning off with the switch) when the battery door is closed? It might be kludgy, but you might fare better using the battery door as an on/off switch rather than trying to open up the camera frame.
Have you pulled the battery and left it out overnight to fully discharge capacitors, etc., inside the camera? https://photography-on-the.net …/showthread.php​?t=1176535
Something you *might* try is some electronic switch contact cleaner (external link). Use only a very small amount around the switch lever and work the lever back and forth. Use at your own risk, though I've never had a problem using it on ham radios and other electronics, but I've never used it on a camera. -?
Intheswamp
Gallery: 89 photos
Joined Sep 2013
Mar 31, 2019 09:20 |  #11
crofter wrote in post #18837888 (external link)
How to: https://support.usa.ca​non.com …page=content&id​=ART109271 (external link)
Clyde29
Joined Mar 2019
Apr 13, 2019 17:26 |  #12
I'll have to order a card reader since I can't seem to find a copy of the EOS utility that I can easily download. I surely don't still have the CD.
Does this camera have a "second battery" or "memory battery?" I can't seem to find it!
Thanks,
Clyde
Tom ­ Reichner
"That's what I do."
Gallery: 213 photos
Location: from Pennsylvania, USA, now in Washington state, USA, road trip back and forth a lot
Apr 13, 2019 17:33 |  #13
I recommend that you call Canon Customer Support at 1-800-652-2666
Whenever I have called, they answer my call promptly and I don't wait on hold at all, and I get someone who speaks English clearly (as a first language). . I have also found that the staff are very knowledgable and helpful.
They will let you know the easiest way of downloading the latest firmware, and they will also be able to guide you to the location of the "memory battery".
There really isn't any viable reason not to call Canon Customer Support in any such matter.
Intheswamp
Gallery: 89 photos
Joined Sep 2013
Apr 13, 2019 20:20 as a reply to  @ Clyde29's post |  #14
about 2/3's the way down the page here should be the EOS Utility: https://www.usa.canon.​com …t2i?tab=Drivers​&Downloads (external link)
*Or*
Copy this link: http://pdisp01.c-wss.com …wNDU4MDAx&cmp=A​BR&lang=EN (external link)
Then click in your browser address window and select "Paste and Go". The download will start immediately.
Best wishes,
Ed
Clyde29
Joined Mar 2019
Apr 17, 2019 19:24 |  #15
Update (4-17-19):
I was able to get the firmware updated. It did not fix the issue. Sometimes the camera will shut off when I switch it to off, but it will come back on within 5 seconds. I'm thinking it's just a faulty switch. I'm now using the battery door as the on off switch... It's getting the job done, but isn't ideal.
8,090 views & 6 likes for this thread, 9 members have posted to it and it is followed by 7 members.
1461 guests, 129 members online
