Flex is Luminar 3 minus the Library/DAM. Use it as a plugin for Lr, Ps, and others.
MCAsan Goldmember 3,918 posts Likes: 88 Joined Jun 2010 Location: Atlanta More info | Apr 05, 2019 20:52 | #1 Flex is Luminar 3 minus the Library/DAM. Use it as a plugin for Lr, Ps, and others.
PictureNorthCarolina Gaaaaa! DOH!! Oops! 9,318 posts Likes: 248 Joined Apr 2006 Location: North Carolina More info | Apr 06, 2019 10:08 | #2 Thanks for the info. As a luminar 3 owner, I'll look into it. I did not get an email. Website
Apr 07, 2019 08:51 | #3 It is free if you own a Luminar 2018 or Luminar 3 license. Copy your Luminar license number from your "My Software" portion of you Skylum. Install Flex and paste in the license number to activate Flex. If you don't activate it, it will be running as a trial copy.
Hen3Ry Goldmember 1,063 posts Likes: 28 Joined Nov 2009 Location: Aptos, CA, USA More info | Apr 07, 2019 08:59 | #4 Picture North Carolina wrote in post #18841124 Thanks for the info. As a luminar 3 owner, I'll look into it. I did not get an email. I stopped using the app when they added the DAM. It caused nothing but problems for me. I can only assume others complaining about the same thing is what generated a DAMless luminar release. I wonder if it's free to registered users. Will find out. Thanks for the heads-up. I don't think so. I have no issues whatever with Luminar 3. However, unless your computer has an awful lot of grunt, I suspect it can be slow, especially to load, if you've pointed it at a huge amount of images. I find Luminar much more useful as a plugin in Photoshop, without the DAM, which isn't accessible when used as a plugin. ***************
PictureNorthCarolina Gaaaaa! DOH!! Oops! 9,318 posts Likes: 248 Joined Apr 2006 Location: North Carolina More info | Apr 08, 2019 09:37 | #5 MCAsan wrote in post #18841667 It is free if you own a Luminar 2018 or Luminar 3 license. Copy your Luminar license number from your "My Software" portion of you Skylum. Install Flex and paste in the license number to activate Flex. If you don't activate it, it will be running as a trial copy. I had a look at the Skylum / Flex page and did not see anything about a free upgrade to Luminar 3 owners, but perhaps I overlooked it. I'll give it a try. Thanks for the info. Website
PictureNorthCarolina Gaaaaa! DOH!! Oops! 9,318 posts Likes: 248 Joined Apr 2006 Location: North Carolina More info | Apr 08, 2019 09:42 | #6 Hen3Ry wrote in post #18841670 I find Luminar much more useful as a plugin in Photoshop, without the DAM, which isn't accessible when used as a plugin. Thanks for the info. I was using Luminar 3 as a standalone. I do not want nor need the dam so I'll give it a go as a plugin. Thanks. Website
| Latest registered member is semonsters 911 guests, 118 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
