Thread started 30 Apr 2019 (Tuesday) 06:33
Canon speedlite 600 ex rt wont fire
Thumbsup
Apr 30, 2019 06:33 |  #1
Does anyone know why my Canon 600 will turn on but won't fire by either pushing the test button or mounted on the camera?
Thank you
John ­ from ­ PA
Joined May 2003
Post edited over 4 years ago by John from PA.
Apr 30, 2019 08:04 |  #2
Similar problems have been reported with this unit.
Some fixes that have worked supposedly is to remove the batteries, turn the power switch ON, install the batteries (switch is still ON), then close the battery door. Make sure the batteries are fully charged or fresh if non-rechargeable.
The other thing to try would be a full factory reset which I believe is in the manual somewhere around page 38
Thumbsup
Apr 30, 2019 08:52 as a reply to  @ John from PA's post |  #3
Thank you for the reply I had my hopes up but tried both of those suggestions and still wont fire I guess I will have to send it in to Canon I know any repair by them is so expensive but I guess its better than buying a new one. Thanks again!
OceanRipple*
Joined Dec 2014
Apr 30, 2019 11:34 as a reply to  @ Thumbsup's post |  #4
Hi, May not work, but standard reset sequence is:
1. Turn the flash off.
2. Remove batteries (or just open the battery door)
3. Turn the flash on.
4. Hit the test button.
5. Turn flash off
6. Put batteries back etcetc
i.e. you missed 'Hit the test button/lamp' while the batteries are out with the On switch to On.
John ­ from ­ PA
Joined May 2003
Apr 30, 2019 14:07 |  #5
There are some people mentioning success with a reset at https://community.usa.​canon.com …-problem/td-p/9779/page/2 (external link). With the procedure mentioned, using button 2 and 3, one guy mentions it worked but he had to do it several times, so keep at it and hopefully you will be met with success.
Thumbsup
Apr 30, 2019 15:27 as a reply to  @ John from PA's post |  #6
Thanks I will try some more!
Grand_gator
Joined Mar 2011
May 01, 2019 23:55 |  #7
I have the same problem, but still it won’t fire. How much is a lamp replacement by canon on this flash (no cps)? Anthony has it done recently?
5Diii / 70-200 L IS II / 100-400 L IS II / 24-105 L IS / 100mm 2.8 L Macro IS / Σ 35mm 1.4 Art / Σ 85mm 1.4 Art / EF-S 10-22mm / EF-S 17-55mm IS / EF 70-300mm IS / 50mm 1.8 II / 600 EX RT + 430 EX II
Thumbsup
May 03, 2019 10:53 as a reply to  @ Grand_gator's post |  #8
Without cps around 160 to 200 dollars! ouch!
N2bnfunn
May 03, 2019 11:48 |  #9
Ok I have 3 600 ex's question are you using rechargeable batteries ?
Have you try using a Q-tip and some alcohol cleaning the battery contacts?
Now this would be your last result: take the positive part of the battery and put in on negative, and the negative on the positive
and turn the power on for 2 or seconds and flip the batteries back to normal sometimes the reverse polarity can get a unit that is
not powering up to work.
Good Luck
Let me know.
Canon EOS R EF 70-200 L 2.8 L 24-70 2.8L II Canon Pixma PRO-1 3 Canon 600EX-RT Speedlites
Thumbsup
May 03, 2019 12:55 as a reply to  @ N2bnfunn's post |  #10
Thank you for the suggestions!
N2bnfunn
May 05, 2019 21:55 |  #11
Hello so give us an update?
Thumbsup
May 06, 2019 13:35 as a reply to  @ N2bnfunn's post |  #12
I joined Canon Cps and I am going to send in for repair.
Grand_gator
Joined Mar 2011
May 06, 2019 23:19 as a reply to  @ Thumbsup's post |  #13
Please, let me know how that goes. I might have to do the same
Thumbsup
May 07, 2019 05:19 as a reply to  @ Grand_gator's post |  #14
I will let you know the cost estimate I am waiting for my cps kit to arrive so I can ship it to them.
5,065 views & 5 likes for this thread, 5 members have posted to it and it is followed by 3 members.
1347 guests, 130 members online
