Hello all!
What's the difference CANON EF 24mm f/2,8 IS USM and Canon 28mm F2.8 IS USM?
The only difference is 4mm ? Everything else will be the same?
What do you think?
Apr 30, 2019 13:47 | #1 Hello all!
kmilo Senior Member 500 posts Likes: 1081 Joined Nov 2009 Location: Albany, NY More info | Apr 30, 2019 13:53 | #2 the 28mm is a touch sharper according to these guys: https://www.opticallimits.com …74-canon28f28isff?start=1 Kris
bseitz234 Senior Member More info | Apr 30, 2019 14:12 | #3 Oleg2010 wrote in post #18853853 Hello all! What's the difference CANON EF 24mm f/2,8 IS USM and Canon 28mm F2.8 IS USM? The only difference is 4mm ? Everything else will be the same? ![]() What do you think? Yep, pretty much.
edrader "I am not the final word" More info | it is. it's also smaller. real gem of a lens. http://instagram.com/edraderphotography/
Jul 12, 2020 22:51 | #5 If you’re doing any kind of real estate photography or taking images of rooms inside a home, then definitely the 24 mm. This is the ideal lens for inside photos. It keeps everything within the most realistic perspective and yet wide.
| Latest registered member is semonsters 1600 guests, 142 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
