Thread started 07 May 2019 (Tuesday) 11:19
Backpacking - single lens?
kaitlyn2004
May 07, 2019 11:19 |  #1
On a lot of my hiking+camping trips, I bring my Canon 16-35 F4 IS + 70-200 F4 IS. Normally walking around with the 16-35 mounted.
Going to be doing some longer trips, and wondering about a single-lens solution. Naturally falling to the 24-105 F4 (over the 24-70 for the longer focal range coverage). Are there other lens to be considering? It's been forever since I've looked at lenses...
I previously owned the 24-105 and didn't love the image quality, but maybe it's worth the tradeoff for space+weight of a single lens. I don't want to TOTALLY sacrifice image quality though...
Finally concern would be if 24 were wide enough (i do often shoot wider with my 16-35) for landscapes... but again, maybe just make do...
My Landscape Photography Videos (external link)
My Instagram (external link)
3Rotor
Gallery: 72 photos
May 07, 2019 11:56 |  #2
The 24-105 is a really nice range to work with. It's the all-around lens I use at work.
For my personal use, replacing the 16-35 with the 24-105 leaves a large void on the wide end for me. It would be tough for me to do. It wouldn't hurt to pull your images into Bridge or Lightroom to see what your most used focal lengths are. That may be able to help you consolidate the two into the 24-105 or rule out the option of just one lens?
www.jessemak.com (external link)
kaitlyn2004
May 07, 2019 15:00 |  #3
Assuming I didn't mess up anything, here is my usage for 2019:
https://i.imgur.com/4A​RBaV2.png (external link)
I think with a 24-70, I could still deal with not having 70-105.. but I do worry that I'll be missing out on the wide end 16-24. I wonder if I bring a 24-70 f2.8 II plus 16-35... 24-70 as my general lens, and 16-35 for "set up" shots like sunrise/sunset type of things where I want wide angle more.
hmmmmmmmmmmmmmm!
timd35
Gallery: 57 photos
Joined Dec 2012
May 07, 2019 15:33 |  #4
On longer backpacking trips where weight and space might be an issue I take only my 24-70. Unless I am trying to really get a lot of foreground in focus I tend to like multi shot Pano's closer to 40-50mm anyway. But that is just me. I tend to miss longer than 70 more than less than 24 on full frame. I tend to like Telephoto landscapes a lot but I do not get myself in good enough shape to take my 70-300L with me :-) up and down the mountains. Since I like taking my 5DIV and 24-70II that is enough weight for me at my age :lol:
This year I will take my EOS R which is a little lighter than 5DIV so we will see. Plus I will be doing day summit hikes this year instead of multi day backpacking.
'Imagination is more important than knowledge.'
—Albert Einstein
http://timdahlphotogra​phy.com
kaitlyn2004
May 07, 2019 16:56 |  #5
timd35 wrote in post #18857954 (external link)
Sounds like we're very much the same. I like taking panoramas too, and when I have my 16-35+70-200, I often want to shoot somewhere in between but don't have the focal range covered!
I wonder if I'll miss having the 70-105, if I choose the 24-70 over the 24-105....
bseitz234
Gallery: 23 photos
Joined Feb 2013
May 09, 2019 11:40 |  #6
Looking at your usage, I think that any solution you decide is going to be a compromise. You're either compromising your focal length range (24-105), image quality (18-200mm), or weight (16-35 + 70-200). I don't know of any single lens that will produce the IQ you're used to, across that broad a range. So unfortunately, the tough question is which compromise is the least of the three evils? Maybe try a shorter and lesser-priority trip where you limit yourself to the 24-105 range with your existing lenses (ie, use the 16-35 as a 24-35 and the 70-200 as a 70-105). Is that enough range for you? It seems silly to bring the 70-200 and use it as a 70mm prime to see if the 24-70 would cover you, but you could try that as well.... Depending on what you didn't love about the 24-105 last time you owned it, there is a v2 out now, but I don't believe the IQ is supposed to be earth-shatteringly-better.
Personally, I was trying to decide what to bring to Machu Picchu in the fall to cover the long end. I'm good carrying a 10-22 and 17-55, but wasn't sure about the long end. Ultimately decided to bring a 100-400 for tele landscape and wildlife, which means committing to a lot more training this summer if I'm going to pull it off... I only mention this because I wouldn't think you're crazy for bringing both lenses on a longer trip. Just crazy strong/fit!
-Brian
5 EOS bodies, and constantly growing lens selection.
IG @bseitz234
Mike ­ B ­ in ­ OK
Gallery: 14 photos
Joined Jun 2019
Jun 21, 2019 17:35 |  #7
Sorry to come along so late, but I would add a suggestion....if I were a backpacker and had the weight concerns most backpackers seem to have, I’d take a Sony RX100 (any of the last few versions would do) instead of an SLR and L lens when I went backpacking. Excellent image quality and lots of options for manual control. I love my Canons, but when I want to take something more than the phone camera, and it isn’t a real photo-centric trip, out comes the Sony.
Spencerphoto
Gallery: 90 photos
Joined Sep 2018
Jun 21, 2019 17:49 |  #8
bannedPermanently
I just came back from a five-week trip to Europe and took my Lumix LX100, which I bought specifically for lightweight travel. It has a 35mm equiv 24-70mm zoom and that is fine, 80% of the time. I would say I missed having a little more on the wide end than the long, but that's because my holiday photo style uses wide angle more than reach.
As for IQ, I find the convenience, lack of bulk (more so than weight) and unobtrusive style (making me less conspicuous and drawing less attention from prospective subjects) makes up for any loss in that area, especially as I never print my holiday pics, only viewing them on a screen. In particular, I find the low-light ability of the little Lumix to be amazing, given the spec and price.
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2019/06/3/LQ_983912.jpg
Photo from Spencerphoto's gallery.
Image hosted by forum (983912)
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2019/06/3/LQ_983806.jpg
Image hosted by forum (983806)
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2019/06/3/LQ_983619.jpg
Image hosted by forum (983619)
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2019/04/1/LQ_970760.jpg
Image hosted by forum (970760)
5D3, 7D2, EF 16-35 f/2.8L, EF 24-70 f/2.8L II, EF 24-105 f/4L, EF 70-200 f/2.8L II, EF 100-400 f/4.5-5.6L II, EF 1.4x III, Sigma 150mm macro, Lumix LX100 plus a cupboard full of bags, tripods, flashes & stuff.
Left ­ Handed ­ Brisket
Gallery: 15 photos
Joined Jun 2011
Jun 21, 2019 19:35 |  #9
Canon is coming out with a 24-240 for the RF mount that could be a game changer for this kind of stuff.
gorben
Joined Mar 2014
Jul 31, 2019 20:55 |  #10
Best backpacking gear I ever carry was the EOS-M + 22mm.
After that I tried to carry 5DIII /24-105 and most recently 5DIII/24-70.
After 10 or 20 miles per days in the mountains, nothing beats the 300g M/22 + gorillapod ߘ. For sure some pictures will not be as you want, but you will take others as good if not better. It forces creativity.
Canon 5DIII, 24-105L, 100-400L vII, 35 f/1.4, 50 f/1.4, 100 f/2.0, 100L f2.8 macro
Fuji X-T10, 18-55 & 27
FlickR (external link)
duckster
Gallery: 466 photos
Joined May 2017
Feb 24, 2020 14:27 |  #11
I have used my Rebel T3i and EFS 24mm f2.8 pancake for hiking with camera and been happy with it for landscapes and such. Not a wildlife rig, however
SYS
Gallery: 602 photos
Joined Jul 2004
Post edited over 3 years ago by SYS. (2 edits in all)
Feb 25, 2020 11:17 |  #12
As I get older, my body aches lot more, so I find myself compromising what gear to carry on what trips a lot more, too. My compromise 5 years ago was to carry the 24-70L for just about everything except for birding and wildlife, but now I even find it heavy, so it's been 16-35L f/4 in most recent years. Eventually, I'll replace my heavy 5D IV to a lighter body.
Most recently, I went hiking with 5D IV and 16-35L f/4 for mostly winterscape shots when I ran into a herd of mule deer. That's when I felt the sting of not having my longer lenses. But no matter, I took photos of these beautiful animals nonetheless, went home, cropped the images in, and they were good enough for my web postings. So, one way to compromise is having the high resolution camera body that could allow you to crop in for those "reach" challenged subjects. Of course, even then some subjects (like birds) just aren't going to work, but then if my primary objective in going out to shoot is birds, then I'd choose my lens accordingly. For hiking, street candids, travels and whatnot, I just stick to 16-35.
-Goethe
SuperSirLink
Gallery: 10 photos
Joined Sep 2017
Mar 03, 2020 06:24 |  #13
I do a lot of backpacking (wilderness) with my X-T2/3 and the 10-24 and now the 16-80. I was carry various primes. For me I leave the 100-400 home as most of the time ~100mm has been more than long enough. So far 80 has been enough to not warrant carrying another lens. I find the wider end to be more beneficial than being in the 100-200 range...
FujiFilm X-T2 & X-T3 | FujiFilm Lenses : XF 16mm F1.4 R WR | XF 10-24mm F4 R OIS | XF 16-80mm F4 R OIS WR | XF 100-400mm F4.5-5.6 R LM OIS WR
Nikon FM2n | Series E Lenses : 28mm/2.8 | 35mm/2.5 | 50mm/1.8 | 100mm/2.8 | 36-72mm/3.5 | 70-210mm/4
Helios 44m 58mm/f2
3,842 views & 3 likes for this thread, 11 members have posted to it and it is followed by 5 members.
1504 guests, 134 members online
