Thread started 23 Mar 2006 (Thursday) 13:20
Very basic question-im new-f/?
Brodog2525
Mar 23, 2006 13:20 |  #1
Hi, I am new here and I have 1 question which I can't find the answer too.
If a camera is listed as 18-125mm f/3.5-5.6 for example.... what does the f/3.5-5.6 mean? I think it has something to do with the aperture/f-stop but I am not sure and would like the correct answer.
So for example what would the different be between
18-125mmf/3.5-5.6
AND
17-85mm f/4-5.6
Canon 30D | 17-85mm EF-S with IS | 430EX Flash
50mm f/1.8 II | 18-55mm lens kit
70-200mm f/4 L
brodiehenry.smugmug.co​m (external link)http://www.BrodieHenry​.com (external link)
jwwill0
Mar 23, 2006 13:24 |  #2
It means that the max aperature is different at different focal lengths. For example, the max aperature at 18mm is f/3.5 and at 125mm it is f/5.6.
*Note: you will see some zoom lenses listed with only one aperature. For example, 70-200 f/2.8. These lenses maintain the same max aperature throughout the zoom range.
~Josh
http://www.joshuawilli​amsphotography.com (external link)
Flicr: http://www.flickr.com/​photos/jwilliams_photo​graphy/ (external link)
Jon
Joined Jun 2004
Mar 23, 2006 13:25 |  #3
At 18 mm the largest f/stop is f/3.5; at 125 mm, it's f/5.6.
Jon
Cocker Spaniels
TNGraham
Joined Feb 2006
Mar 23, 2006 13:27 |  #4
The f/3.5-5.6 refers to the widest aperture that a lens has. In the case of the 18-125mm f/3.5-5.6 lens that you mentioned the widest aperture changes from 3.5 to 5.6 depending on the focal length that you are using on that zoom lens.
20D, 17-40mm f/4 L, 24-105mm f/4 L, 50mm f/1.4, 70-200mm f/4 L, 100mm Macro, Speedlight 580ex
Brodog2525
Mar 23, 2006 13:37 |  #5
oh! thanks very much for the quick response. that makes perfect sense. thank you!
70-200mm f/4 L
In2Photos
Mar 23, 2006 13:38 as a reply to  @ Brodog2525's post |  #6
And welcome to the forum.
Current Gear and Feedback
jngo
Mar 23, 2006 16:33 |  #7
i had no clue what that meant eiter when i first entered photography...funny because it's one of the most important factors when considering a lens...
chemicalbro
Joined Jun 2005
Mar 23, 2006 20:45 |  #8
18-125mmf/3.5-5.6
AND
17-85mm f/4-5.6
as everybody said its the max aperture....
the difference between the 2 lenses you stated is that the 18-125 is slightly faster at the wide end (able to take pictures in less light at 18mm at the same shutter speed as the 17-85 at 17mm)
both are the same speed at the zoom end...
Alan
1,427 views & 0 likes for this thread, 7 members have posted to it.
1519 guests, 131 members online
