The collar has some years on it and has started to slip and rotate a bit. I'm thinking I could just add a little thin fabric to the inside and tighten up things. Any suggestions on a material to use, or a different plan completely?
chuckmiller Goldmember More info Post edited over 4 years ago by chuckmiller. | May 16, 2019 18:59 | #1 The collar has some years on it and has started to slip and rotate a bit. I'm thinking I could just add a little thin fabric to the inside and tighten up things. Any suggestions on a material to use, or a different plan completely? .
May 16, 2019 21:04 | #2 chuckmiller wrote in post #18862532 The collar has some years on it and has started to slip and rotate a but. I'm thinking I could just add a little thin fabric to the inside and tighten up things. Any suggestions on a material to use, or a different plan completely? I have the 70-300L which I bought an aftermarket collar for but I stopped using or installing the collar as it was marring the paint on the lens. My first choice was to line the collar with a thin felt type material. Easy to install using two sided tape. I never did do it but I think it would work quite well. I never went beyond the this should work stage. Just stopped using the collar. >>> Pictures? What pictures? <<<<
iroctd Senior Member 343 posts Likes: 66 Joined Aug 2013 Location: East coast More info | May 17, 2019 19:05 | #3 Just preliminary thinking of what I might do in this situation. Get a nice microfiber cloth, I like these if they are the right size:
| Latest registered member is IoDaLi Photography 1791 guests, 129 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
