Looking for ball head which may safely take 300mm f/2.8 L II lens with Extender 1.4x. Please suggest.
Jai.
Jun 11, 2019 02:54 | #1 Looking for ball head which may safely take 300mm f/2.8 L II lens with Extender 1.4x. Please suggest.
SYS Cream of the Crop More info | Jun 11, 2019 08:59 | #2 I'm sure you'll have a few other suggestions, but the one that I own and love and suggest is RRS BH-55 LR.
bpalermini Goldmember More info | I also would recommend the BH-55. Bob
Jun 11, 2019 16:29 | #4 Personally I would not recommend a ball head for that lens as I have one! Life is for living, cameras are to capture it (one day I will learn how!).
Jun 12, 2019 07:37 | #5 I've gone through the Arca-Swiss Z1, RRS BH-55, and finally landed on the FLM CB-48FT on the heavy duty front. The Z1 doesn't do well when it's raining, the BH-55 had an apparently malfunctioning friction control, and so far the CB-48FT has been great. There are three models of the CB-48; CB-48F, CB-48FT and CB-48FTR. The F models have a friction control that works really well, the FT models have that plus a tilt control, and the FTR has an additional dual lock design that uses two separate knobs to control the movement of the ball and the panning base. All the CB-48 models have a load capacity of 99lbs. Image hosted by forum (982321) © peter_n [SHARE LINK] THIS IS A LOW QUALITY PREVIEW. Please log in to see the good quality stuff. ~Peter
Jun 12, 2019 21:47 | #6 Thank you all for your valuable suggestions. Will help me lot in making decision.
Jun 12, 2019 23:14 | #7 I have used an older model Kirk BH-1, Arca Swiss Z1, and now a FLM CB-48F. A friend has the RRS BH-55. Many love the Sirui K40x. - John
goalerjones Goldmember More info Post edited over 4 years ago by goalerjones. | Jun 12, 2019 23:23 | #8 I've been using this one for over a year now, not too expensive but holds 66lbs.
fotopaul Senior Member 560 posts Likes: 476 Joined Jul 2015 Location: Stockholm/Sweden More info | Jun 13, 2019 14:36 | #9 FLM does make good ball heads, I had the FLM-48FTR as well, a great ball head. Never did use the tilt function much though.
Jun 30, 2019 14:13 | #10 The only ballhead I’ve used that didn’t eventually creep was the RRS bh-55.
fotopaul Senior Member 560 posts Likes: 476 Joined Jul 2015 Location: Stockholm/Sweden More info | Jun 30, 2019 14:54 | #11 rick_reno wrote in post #18886296 The only ballhead I’ve used that didn’t eventually creep was the RRS bh-55. So all ball head except the BH-55 will creep even though you locked them down ?
My Kirk BH-1, Arca-Swiss Z1, and FLM CB-48f have never, ever crept. I had the Kirk head for over 11 years without a single problem. - John
Bianchi Cream of the Crop More info Post edited over 4 years ago by Bianchi. (4 edits in all) | Aug 23, 2019 08:51 | #13 Interesting no one mentioned the Acratech GP >> Kirk, RRS & FLM are all excellent manufactures, but in my personal opinion a fluid head is the best of two worlds, Stills and Video.. You just need to know how to set them up properly, and once you use one set up properly you may ask yourself, why have I been using a ball head for so long.
fotopaul Senior Member 560 posts Likes: 476 Joined Jul 2015 Location: Stockholm/Sweden More info | Aug 23, 2019 12:16 | #14 |
Bianchi Cream of the Crop More info Post edited over 4 years ago by Bianchi. (2 edits in all) | Oct 06, 2019 16:27 | #15 fotopaul wrote in post #18915167 A video head takes up A LOT more space thttps://photography-on-the.net …s/editortools_size.pnghan a ball head, especially if you're using a quality one. The one used in the video is ok, but certainly not the best quality we had to replace two of them... before giving up on the poor pan lock. Agree a little more real estate than a conventional ball head, however I have not had experienced what you experienced with the pan lock.. Perhaps due to your extreme weather temps in Scandinavia, however that's just an educated guess.. What was your perspective as to failure of the pan lock for you ?
| Latest registered member is Niagara Wedding Photographer 1253 guests, 116 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
