Thread started 15 Jun 2019 (Saturday) 19:59
1D Mark IV is randomly under-exposing photos
waterrockets
Joined Jun 2010
Jun 15, 2019 19:59 |  #1
Have not been able to figure this out yet. Sometimes, while shooting AV with a manual ISO, the camera just under exposes a handful of shots. The histogram is way to the left, and it's just dark. Then it will snap out of it and shoot a few dozen shots at proper exposure, same scenes even.
Anyone seen this?
Thanks in advance!
1D MkIV | 1D MkIII | 550D w/grip & ML| EF 70-200mm f2.8L| EF 24-105mm f4L IS | Canon EF 100-400mm f/4.5-5.6L IS | Samyang 14mm f/2.8 IF ED UMC | 430EXii | EF 50mm f1.8
trekgod3
Jun 16, 2019 06:09 |  #2
Is safety shift enabled ? Have you tried disabling it?
1dx mark ii, 6d mark ii, Canon 24-70f2.8L ,Canon 70-200f2.8 IS iiL ,Canon 24-105 f4 L, Canon 100-300 f5.6L, Tamron 150-600, Canon 2x extender iii, Speedlite 580ex, Speedlite 430ex , Speedlite 270ex
Capn ­ Jack
Gallery: 2961 photos
Jun 16, 2019 08:13 |  #3
Check the lens is properly secured.
I was getting over-exposure on a 7D2 the other day- found the lens was loose. A twist to lock it fixed the problem.
I did read you have an over exposure problem, I'm wondering if the aperture setting isn't being received by the lens and it is stepping down? In my case it was stepping up- I don't know if all lenses work the same way when disconnected.
waterrockets
Joined Jun 2010
Jun 16, 2019 20:44 |  #4
trekgod3 wrote in post #18878530 (external link)
No, it's disabled. Unchanged in the 4 years I've had the camera (this is a new problem).
waterrockets
Joined Jun 2010
Jun 16, 2019 20:45 |  #5
Capn Jack wrote in post #18878569 (external link)
This happens with four lenses, including one with a mechanical aperture selection ring (shooting AV).
apersson850
Obviously it's a good thing
Gallery: 35 photos
Jun 17, 2019 03:16 |  #6
Does the shutter sound the same when this happens, compared to when good pictures are taken?
I'm thinking maybe it moves, but incorrectly, so it doesn't open when it moves.
Anders
waterrockets
Joined Jun 2010
Jun 17, 2019 08:28 |  #7
apersson850 wrote in post #18878987 (external link)
Interesting thought. I'll have to try to notice this -- nothing that caught my attention. What does shutter failure look like?
Examining a few photos, it appears that it usually happens for all shots in a series, and the EXIF shows that the shutter speed is way too fast on the dark shots. One series will be at 1/8000, for instance, underexposed, and the next series in the same conditions/subjects will be at 1/3200. So it seems that the camera recognizes what it's doing, so it feels like a metering problem. I have been shooting with "center weighted averaging" for years, including in these shots.
Wilt
Jun 17, 2019 10:11 |  #8
A simple test...aim the camera at a featureless uniformly colored and uniformly illluminsted wall, and take a lot of shots in succession.
Do this in Av, then in M (using same settings as indicated by the meter while in Av). All should result in uniformly dense exposures.
Variations while in M will indicate shutter deviations; variations in AV mode will indicate meter induced variations
waterrockets
Joined Jun 2010
Jun 17, 2019 11:01 |  #9
Wilt wrote in post #18879151 (external link)
Thanks. I'll see if I can set something up.
At any rate, this doesn't seem like a common problem.
Canon ­ Amateur
Gallery: 50 photos
Jun 17, 2019 15:15 |  #10
Two things pop into my mind.
1: What setting do you use for Metering, Spot metering ?
2: Do you have the vertical grip switch on ?
When I have the vertical grip on, I occasionally press the * button with my hand when in normal position.
And because I have the "Hail Mary" settings from CyberdyneSystems enabled, the camera behaves different when pressing *.
https://photography-on-the.net …showthread.php?​p=17951424
CyberDyneSystems post #4812
Switching off the vertical grip and everything is back to normal.
Canon EOS 1Dx / 5D4 / 5Dsr / Fujifilm X-T4 / Lytro illum
waterrockets
Joined Jun 2010
Jun 20, 2019 13:01 |  #11
1: Center Weighted Average
2: Yes, vertical grip is on. I don't have hail mary set up -- but may be bumping * -- will check if that's causing this somehow.
Thanks!
Canon Amateur wrote in post #18879307 (external link)
2cruise
Gallery: 1182 photos
Best ofs: 7
Jun 24, 2019 17:32 |  #12
Thanks, I did the test this morning on my 1DMKIV and it passed with flying colors.
R6~ ef100-400 II L~ Canon 1.4 extender III~ Canon 100mm 2.8 L Makro~Tamron 24-70 2.8 G2~ Tamron 70-200 2.8 G2~ Tamron 85mm 1.8~IRIX 15mm f/2.4 Blackstone~Lee filters
My Flickr (external link)
Wilt
Post edited over 4 years ago by Wilt. (3 edits in all)
Jun 24, 2019 20:06 |  #13
2cruise wrote in post #18883210 (external link)
Good news: it passed the recent tests
Bad new: What caused the problem when it occurred?!
You still have no idea if the metering is somewhat flakey, or if the shutter is somewhat flakey! The purpose of my suggested test was to help determine the root cause of the exposure change that you had observed.
TeamSpeed
01010100 01010011
Gallery: 116 photos
Joined May 2002
Post edited over 4 years ago by TeamSpeed.
Jun 24, 2019 21:04 |  #14
Wilt wrote in post #18883284 (external link)
The OP didn't reply that they passed with flying colors, it was someone else. As to the root cause of the OP, I have to assume metering mode is the culprit. AF point linked metering vs not could cause unexpected results.
Wilt
Jun 25, 2019 00:53 |  #15
TeamSpeed wrote in post #18883309 (external link)
Good point. Although I have never owned/used a 1Dn body, it would seem that spotmetering using the AF zone + focus-recompose could really confuse things!
7,972 views & 7 likes for this thread, 14 members have posted to it and it is followed by 6 members.
1457 guests, 134 members online
