Is it normal for a 1D MKIII battery to get real hot when charging?
stronics Member 90 posts Likes: 21 Joined Sep 2013 Location: NE Ohio More info | Jun 27, 2019 16:51 | #1 Is it normal for a 1D MKIII battery to get real hot when charging?
Jun 27, 2019 17:26 | #2 No. It may get a little warmer than room temperature but it certainly should not be hot to the touch. Life is for living, cameras are to capture it (one day I will learn how!).
Thanks for the reply. My battery gets too hot to hold in your hands. I just bought the camera and still learning. I guess I will be making some phone calls.
Jun 28, 2019 16:17 | #4 stronics wrote in post #18884777 Thanks for the reply. My battery gets too hot to hold in your hands. I just bought the camera and still learning. I guess I will be making some phone calls. Thanks David That sounds serious! Lithium Ion batteries are normally pretty safe but when they get that hot bad things can, and probably will, happen! Do not use or charge it. Life is for living, cameras are to capture it (one day I will learn how!).
I agree. I've heard things like that bursting into flames. I called the dealer and they are sending me a replacement Monday.
TeamSpeed 01010100 01010011 More info | Jun 29, 2019 16:15 | #6 If the outer shell starts to fill with gas from overheating and then gets punctured or breaks open, then you have cause for concern. Is the charger the Canon factory charger? Past Equipment | My Personal Gallery
Good to hear that they are sorting it for you. Life is for living, cameras are to capture it (one day I will learn how!).
stronics THREAD STARTER Member 90 posts Likes: 21 Joined Sep 2013 Location: NE Ohio More info Post edited over 4 years ago by stronics. | Aug 03, 2019 17:56 | #8 Thanks all for the information, I called B&H and they sent me another one fast. I take it that they shouldn't get that hot. Yes it was a Canon charger, original equipment.
Aug 04, 2019 03:25 | #9 Well spotted! You really don't want to mess with defective Li-ion batteries.
| Latest registered member is semonsters 1058 guests, 115 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
