PhotosGuy wrote in post #18886111
The white card is used instead of the gray card in low light situations.
PentaxShooter wrote in post #18886206
I've always used white for WB, grey for exposure.
Thanks to you both.
1. Are you guys using an in-camera custom WB, or doing it in post, or both ?
2. In post, it is my understanding that, if your program has three color-pickers, one should use the picker that coincides with the color of card used; however, some programs only have a single picker/sampler; in such a program, for correcting/setting WB, I am guessing the white card would be preferable to the grey ?
3. I am often shooting outdoors, most likely in an open field, between 9:AM and 3:PM, with the sun beating down or partially cloudy. I will be moving from subject to subject, taking shots from all four sides; hand-held and "point-n-shoot."
In such conditions, can I set WB once and that be okay for all of my shots (considering the overall lighting remains the same); or, would I be better off just letting the camera decide and hope for the best ?
>>> On EDIT: Subjects usually are trains, and antique/classic tractor and engine shows.
