My Orlit Rt 610 has started making an obvious popping sound at higher power levels. Maybe the bulb? It still seems to work but it's almost scary at full power because it's so loud. Is something going wrong with it? properly
Jul 29, 2019 19:22 | #1 My Orlit Rt 610 has started making an obvious popping sound at higher power levels. Maybe the bulb? It still seems to work but it's almost scary at full power because it's so loud. Is something going wrong with it? properly
Lotto Goldmember 2,750 posts Likes: 192 Joined Mar 2005 Location: Southern California More info | Jul 30, 2019 02:16 | #2 Check the glass dome is mounted properly? Or take it off to see if makes any difference. 5D, 24-105L, 70-200L IS, 85mm Art, Godox
simonbarker Senior Member 253 posts Likes: 65 Joined Mar 2009 More info | Aug 12, 2019 17:19 | #3 Well... besides the pop of the flash tube firing I'd normally expect a popping sound to be made by the caps if they're in trouble.
| Latest registered member is semonsters 1431 guests, 139 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
