Hi there,
We went on a trip to Doha in Qatar, brought my new D5300 with its original, fully recharged MH-24 battery. (I forgot to carry a backup battery unfortunately.)
The camera has stopped working after 2 hours of walking around the city shore. The battery indicator showed full, than the next time I tried to turn on the camera, it didn't respond at all anymore.
I guessed it was about the weather, it was unbelievably high humidity in addition to the 38 degree Celsius temperature there. We felt like if we breathe hot water on our whole trip, sweating heavily, not a single inch on our clothes survived dry.
After the trip, I realized that the battery was strangely depleted (from full to zero in around 15 minutes while the camera was turned off), we leaved Doha, I recharged it and it worked fine again.
On our next stop Da Nang, Vietnam (same temperature but less humidity) the problem repeated similarly, but this time I wasn't able to turn on the camera after recharging the battery, even if the charger indicated it's fully recharged. I left the camera on the apartment's table for a few hours and when I tried to turn it on again the camera is miraculously went live (with the battery indicator that showed it full).
From the symptoms, what do you think? Due to the hot wet weather, the battery broke down, or the camera itself malfunctioned? Is it possible anyway that the camera circuits go haywire because getting wet from air humidity? I don't believe it's normal, and a company like Nikon makes cameras that can't be use in cities like Doha. Should I require an inquiry for investigation under the product's warranty?
