I am wanting to shot some astro photography and my wide lens is the canon 17-40 f4. Is it enough or do I need a faster lens?
Aug 15, 2019 10:58 | #1 I am wanting to shot some astro photography and my wide lens is the canon 17-40 f4. Is it enough or do I need a faster lens?
LeftHandedBrisket Combating camera shame since 1977... More info | Aug 15, 2019 11:05 | #2 What are you attaching it to? PSA: The above post may contain sarcasm, reply at your own risk | Not in gear database: Auto Sears 50mm 2.0 / 3x CL-360, Nikon SB-28, SunPak auto 322 D, Minolta 20
Aug 15, 2019 11:07 | #3 Faster lenses will always help but current sensor technology with higher usable ISO has come a long ways. Lenses that couldn't perform in the past has been given new life with modern sensors. What body are using?
Aug 15, 2019 12:15 | #4 I will be using a Canon 6D
gjl711 Wait.. you can't unkill your own kill. 57,733 posts Likes: 4065 Joined Aug 2006 Location: Deep in the heart of Texas More info | Aug 15, 2019 12:34 | #5 Much depends on what you are looking to do but generally f/4 is fine. Just compensate with higher ISO or longer time or both. Not sure why, but call me JJ.
Aug 15, 2019 17:34 | #6 If your shooting in a very dark place the f/4 will have a hard time on very short exposures unless it’s mounted on a tracking mount and aligned properly . But if your on a stationary tripod you’ll want exposures less than 20-secs unless your doing star trail images . F/2.8 or wider is highly suggested with shorter exposures cause you can use lower ISO to help minimize noise .
Mtk Member 167 posts Likes: 74 Joined Nov 2009 Location: Montauk, NY More info | Aug 18, 2019 12:49 | #7 F4 will get you started. 2.8 or faster will be better but with your 6d you are at a good start. Wide field Astro is gear dependent but there is a ton to learn and the setup you already have will get you started. If you feel you need faster you can always get a rokinon 14 2.8. Canon 7D, Canon 100-400 F4/5.6 ISL Canon EF-S- 10-22
Oct 21, 2019 04:37 | #8 Late reply but if you're willing and able to stack images for noise reduction, you'll be fine at f/4. Just be ready to take more images. Fuji X-T4, 18-55 and 55-200 zooms, Samyang 12
| Latest registered member is semonsters 972 guests, 108 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
