Thread started 25 Aug 2019 (Sunday) 23:58
Sigma 18-35 dock AF adjust - Issues & resolution.
n1as
Aug 25, 2019 23:58 |  #1
Been swapping gear around. Got a used 7D II body and some lenses including a brand new Sigma 18-35 f/1.8 with the dock. I went through the micro focus adjust dance with all the lenses saving the Sigma for last.
I dialed the Sigma in at the 3 close distances and was able to get it spot on. Very reliable, very repeatable. Beautiful. But infinity was totally terrible. The lens would grossly back focus then front focus at infinity. Totally not repeatable. I figured I'd have to exchange it for another.
Then I had an idea. What if I first adjusted the W and T micro-focus settings in the 7D II and then used the dock to fine tune it from there?
Much to my surprise, the lens was terribly inconsistent at infinity until I found the right micro-focus setting. Then it settled down and behaved like a normal lens. After getting the W and T values dialed in on the 7D II then went back to the dock.
Dock values were different this time but again, the lens was stunningly consistent and repeatable. It was pretty easy to get it all dialed in for the 3 close distances. I went outside and shot some infinity pics, making sure I had stuff in the foreground to find any front-focus. Sure enough, the lens was repeatable and front-focused at 18mm. Back to the Sigma dock and dial in some FF correction and that did the trick. Sharp images at infinity!!!
What was so shocking to me was how random AF was until I got the in-camera MFA values set. Now, mind you the lens is not 100%. I still get some infinity pics that are not in focus but the number is probably in the 10% or less category rather than the 80% to 90% that it was.
- Keith
http://darwinphoto.zen​folio.com (external link)
ed ­ rader
"I am not the final word"
Aug 26, 2019 01:16 |  #2
welcome to sigma!
5D4 x2, 16-35L F4 IS, 24-70L II, 70-200L F4 IS II, 100-400L II, 14L II, sigma 15 FE, sigma 28 f1.4 art, tc 1.4 III, 430exII, gitzo 3542L + markins Q20, gitzo GT 1545T + markins Q3T, gitzo GM4562
Ah-keong
Gallery: 132 photos
Joined Apr 2016
Aug 27, 2019 02:28 |  #3
Lucky that my copy was good out of the box without the need for dock.  :p
Canon R3 | RP | 7D2+grip | EF 70-200mm f/2,8L IS II | EF 135mm f/2L | EF 50mm f/1,2L | RF 100mm f/2,8L | Tamron 24-70mm f/2,8 VC G2 | Tamron 17-35mm f/2,8-4 Di OSD | ZE 2/100mm | ZF 2/35mm | ZF 1,4/85mm | ZF 2/135mm | CV 1,4/58mm Nokton | Micro-Nikkor 60mm f/2,8D | DC-Nikkor 105mm f/2D | Micro-Nikkor 200mm f/4D |
Speedlite 430EX III-RT | 600EX-RT |
Manfrotto BeFree Travel | MT055XPRO3 |
n1as
Aug 30, 2019 13:06 |  #4
I got nervous about AF accuracy for the lens so I bought a used EF-S 17-55 think I'd ship the Sigma back.
I dialed in the micro-focus on the EF-S and then did a walkabout with both lenses, shooting the same scene at the same settings to compare the lenses. After some 50 shots each, I found the AF accuracy of the Sigma at f/2.8 equaled the Canon wide open at f/2.8. They both had 20+ accurate focus events and only one miss.
At f/1.8 the in-focus rate for the Sigma was worse but it still hit focus more times than it missed. I suspect I could improve the infinity f/1.8 performace by some more attention to the MFA settings in the camera.
While the EF-S 17-55 f/2.8 IS USM is a great lens the Sigma is a more interesting lens. It can do the shallower DoF that you don't get on a crop sensor at f/1.8 and it produces crisper sunstars at f/16. At the mid aperatures, the Sigma and Canon are both sharp but the Sigma is sharper at the edges & corners, especially toward the telephoto end of their range.
So which do I keep?
Both, of course :-)
- Keith
Ah-keong
Gallery: 132 photos
Joined Apr 2016
Sep 04, 2019 03:41 |  #5
From experience, I would not use AI servo when using the Sigma.
If accuracy is required, I would use the live view - Dual Pixel CMOS AF which the 7Dii has.
It would be better to change a new copy if your copy don't work consistently.  :p
SMP_Homer
Gallery: 29 photos
Sep 05, 2019 09:06 |  #6
I've always found myself to have been extremely lucky with Sigma stuff - dozens of lenses, and probably just as many bodies (hundreds of possibilities)
ever since adjustments were available in-camera, I either didn't have to change a thing, or the changes were minimal and quick.
Then the global line came out, with the dock, and same thing... minimal if anything, and quick to do
Until I got the 1D IV..... actually, until a friend decided to mount the Sig35A to my 1D4.... in-camera would not adjust it at all - would come close, but not close enough!
I never noticed because, to me, the 35 on a crop isn't a thing I want to do all that much...
Every other Sig lenses I could throw at it is just fine.
I haven't bothered taking it through the dock to make it better - if I'm using the 35, it would be on a full frame
EOS R6’ / 1D X / 1D IV (and the wife has a T4i)
Sig35A, Sig50A, Sig85A, Sig14-24A, Sig24-105A, Sig70-200S, Sig150-600C
100-400L, 100L, 100/2, 300 2.8L, 1.4x II / 2x II
600EX-II X3, 430EX-III X3
mwsilver
Gallery: 54 photos
Joined Oct 2011
Sep 06, 2019 23:06 |  #7
n1as wrote in post #18916626 (external link)
That is interesting because I did something similar with my Sigma 18-35 on my 7D Mark II. I adjusted the camera's lens micro adjustment first and then fine tuned the settings using the dock.
Mark
Nikon Z fc, Nikkor Z 16-50mm, Nikkor Z 40mm f/2, Nikkor Z 28mm f/2.8 (SE), Nikkor Z DX 18-140mm, Voigtlander 35mm f/1.2, Voigtlander 23mm f/1.2, DXO PhotoLab 5 Elite, DXO FilmPack 6 Elite, DXO ViewPoint 3
1,951 views & 1 like for this thread, 5 members have posted to it and it is followed by 3 members.
1505 guests, 131 members online
