Has anyone ever noticed a sensor cleaning being done when opening the card door on a 1DX? I don't think I've ever seen this before with mine until this evening. Seems to have randomly just started...
Edit: happens with the camera turned off.
CaPpedDoG Member More info Post edited over 4 years ago by CaPpedDoG. | Sep 05, 2019 21:17 | #1 Has anyone ever noticed a sensor cleaning being done when opening the card door on a 1DX? I don't think I've ever seen this before with mine until this evening. Seems to have randomly just started...
apersson850 Obviously it's a good thing More info Post edited over 4 years ago by apersson850. | Sep 06, 2019 03:26 | #2 I don't open that door very often, so no. But sensor cleaning is typically initiated by turning the camera on/off, and there's such a switch in the card door too, so... Anders
joeseph "smells like turd" More info | Sep 06, 2019 03:41 | #3 Just picked up mine - was turned off, no sign of sensor cleaning when card door opened... some fairly old canon camera stuff, canon lenses, Manfrotto "thingy", and an M5, also an M6 that has had a 720nm filter bolted onto the sensor:
apersson850 Obviously it's a good thing More info | Sep 06, 2019 05:59 | #4 It doesn't do it every time you operate the on/off switch either. Anders
Sep 06, 2019 12:19 | #5 apersson850 wrote in post #18922386 I don't open that door very often, so no. But sensor cleaning is typically initiated by turning the camera on/off, and there's such a switch in the card door too, so... Appreciate the reply. So you believe it's normal? It's weird, all the years of owning this camera, I've never noticed it.. joeseph wrote in post #18922390 Just picked up mine - was turned off, no sign of sensor cleaning when card door opened... Thanks for checking. Messing around with mine a little more, I've noticed it mostly seems to happen when there are no cards inserted. So, camera off, door closed, no cards... open door, sensor cleaning occurs...
| Latest registered member is semonsters 1158 guests, 110 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
