Thread started 19 Sep 2019 (Thursday) 19:32
Canon 100-400 1st gen
JMAST
Sep 19, 2019 19:32 |  #1
My Canon 100-400 1st gen push/pull lens cannot tighten anymore ... are there any solutions ?
7D w/Canon grip, G12, 30D w/Canon grip, Canon 70-200L 2.8 , Canon 100-400L, Canon 28-135 IS 3.5 ,Sigma 18-50 2.8,Tokina 11-16 2.8,Canon 50 1.8
http://j-mastalerz.smugmug.com/ (external link)
Choderboy
I like a long knob
Gallery: 185 photos
Post edited over 4 years ago by Choderboy. (3 edits in all)
Sep 19, 2019 19:42 |  #2
It's against forum rules to say "do a search".
However if you do search, use this:
In Forums = Canon EF and EF-S Lenses
Title = Friction
That results in 4 threads with lots of info.
I don't know if search links work, I guess I'm about to find out:
EDIT: link removed, it does not work!
Dave
Image editing OK
joeseph
"smells like turd"
Gallery: 263 photos
Joined Jan 2004
Post edited over 4 years ago by joeseph.
Sep 20, 2019 03:23 |  #3
My 100-400 had the opposite problem - zoom barrel seized...
I think Canon has discontinued support for these lenses so you'd need to either find a repair center that would take it on, or do the repair yourself.
If it's any help, the zoom barrel is part number CY1-2833-000 and it should come with the tightening mechanism ring as one unit.
I say "should" because there are some sellers that remove the "zoom band" and sell it seperately
The band on it's own is part YA2-3642-000 but would require fitting of millions of tiny ball bearings so if it was a DIY job, I'd strongly suggest you get a complete zoom barrel.
My lens I took apart & removed the zoom band altogether- not really difficult and you don't need to upset any of the lens adjustments to remove/replace.
check out: https://photography-on-the.net …showthread.php?​p=18697752
there's a link in there to a French DIY repair blog that contains some info on 100-400mm repair.
TF posting: here :-)
JMAST
Sep 20, 2019 18:53 as a reply to  @ joeseph's post |  #4
Thanks for the info.
1,194 views & 1 like for this thread, 3 members have posted to it.
1130 guests, 171 members online
