Thread started 20 Sep 2019 (Friday) 19:56
Articulated Arm for Strobe?
Temma
Gallery: 62 photos
Joined Sep 2009
Sep 20, 2019 19:56 |  #1
I need to mount a couple of Flashpoint 300 strobes to opposite sides of a table.
Is there some sort of articulated arm sturdy enough for that purpose.
If not, is there a reasonable alternative.
I'm trying to avoid light stands as I have limited working space.
RicoTudor
Joined Jul 2014
Sep 20, 2019 20:05 |  #2
If you're willing to mar the surface then nailing a "pigeon" or two into the table will give you secure mounting for heavy strobes and no floor space needed (I don't think any clamping solution will be strong enough). Otherwise, consider a junior stand and two grip arms for positioning the strobes.
Canon, Nikon, Contax, Leica, Sony, Profoto.
Wilt
Sep 20, 2019 20:43 |  #3
Manfrotto has a number of bases/clamps, a number of articulated arms, and you can adapt the ends to have a flash shoe or screw directly into a threaded base.
SYS
Gallery: 602 photos
Joined Jul 2004
Sep 20, 2019 20:55 |  #4
This is what I use (with super clamp):
https://www.amazon.com …28:pla-316724729174&psc=1 (external link)
-Goethe
Left ­ Handed ­ Brisket
Gallery: 15 photos
Joined Jun 2011
Post edited over 4 years ago by Left Handed Brisket.
Sep 20, 2019 21:11 |  #5
If you have a small space, don't "mount" anything to anything remotely close to permanently. Having options is key. Matthews c stand 40" arm and an extra knuckle will put two lights above your table.
Temma
Gallery: 62 photos
Joined Sep 2009
Sep 20, 2019 21:44 |  #6
Thanks for the suggestions.
The table is a DIY macro table made from 3/4" structural pipe with a 2"x4"x3/4" plywood top. On top of this sits 12"x18"x5/8" steel plate on which are bolted 80/20 aluminum beams holding the Wemacro rail and camera.
Since the plate is oriented along the long axis of the table, there isn't a lot of room along the length of the table to mount things.
I have a wooden bar mounted horizontally to the pipe frame along either side using pipe hangers. I use these to mount studio lights mounted on microphone boom arms. I'd like to be able to use those bars if I can get enough distance from the subject and diffuser. I don't need a big range of movement, just enough to align horizontally with the subject and have enough separation from it.
NDAPhoto
Joined Jul 2015
Post edited over 4 years ago by NDAPhoto. (2 edits in all)
Sep 21, 2019 08:46 as a reply to  @ Temma's post |  #7
The Super Clamp System with long studs or Magic Articulating Arms is well suited for this. Autopoles between floor and ceiling are another option with minimal footprint. It’s a worthwhile investment if you’re going to use them regularly, but you can also figure out DYI alternatives. I also have an old Manfrotto system with short 8” and 12” poles designed to hang studio lights from rafters, but I don’t think it’s sold anymore. Those pop up on eBay every now and then. Super Clamps however are key. Sounds like you might just need super clamps with the 823 or long studs.
IMAGE: https://manfrottotripodparts.com/accessories/Superclampposter.jpg
tcphoto1
Gallery: 47 photos
Post edited over 4 years ago by tcphoto1.
Sep 21, 2019 09:37 |  #8
NDAPhoto is correct, a Matthews Super Clamp and arm will work in just about any situation. I have about six of those clamps in my grip bag, so I'd use one with the post from the background stand to secure a light.
www.tonyclarkphoto.com (external link)
www.tcphoto.org (external link)
pat.kane
Sep 21, 2019 16:58 |  #9
Matthellini clamps are also a great option, though they're not articulated. They open much wider than the super clamps, so you can add non-marking blocks between the clamp and table.
https://products.msegr​ip.com …clamps?variant=​6559947587 (external link)
1Dx Mk II, 5D4 and some L glass (gear list / feedback)
http://MaxPreps.DMVpix​.com (external link)
http://www.DMVpix.com (external link)
Oceanripple**
Joined Sep 2019
Post edited over 4 years ago by Oceanripple**. (2 edits in all)
Sep 22, 2019 04:58 |  #10
Magic Arms are great for versatility - but if you reach their limit for payload, you can go a little higher, payload wise, using 2 or more Gags:
https://www.bhphotovid​eo.com …ews_429614_Matt​h_Gag.html (external link)
- along with 5/8th in Arms & Pins.
In this role, avoid smooth bore Gags - you want circular jaws with both V profile and ridged cut-outs for max grip.
Kupo also make Gags of this pattern but I think not for sale in the US.
Temma
Gallery: 62 photos
Joined Sep 2009
Sep 23, 2019 11:02 |  #11
I ended up using c-clamps to hold my Smith-Victor tabletop light stands to the bars that run along the length of the table. Rather than legs, they have flat plates which I clamped to the bars.
Temma
Gallery: 62 photos
Joined Sep 2009
Post edited over 4 years ago by Temma.
Sep 23, 2019 19:55 |  #12
My immediate solution:
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2019/09/4/LQ_1000843.jpg
Image hosted by forum (1000843) © Temma [SHARE LINK]
2,890 views & 1 like for this thread, 9 members have posted to it and it is followed by 4 members.
1026 guests, 107 members online
