tim wrote in post #18937189
Generally it's best to copy your images to your computer, into a sensible folder structure, before editing. Computer disks are faster than memory cards. Any files your image software creates in the folders should be left alone unless you fully understand what they're for.
“Tim” brings up a good point in that an operation that writes to the card, should not be done by the PC. Some people feel it isn’t even recommended to format the card in the PC. Although the evidence is anecdotal, some people feel it isn’t a good idea to delete images while a card is in a card reader or PC slot. Some people have reported card issues like loss of some or all images, and often they were involved with a deletion operation. Having said that, it often is difficult to reconstruct what someone did so better to play safe.
I personally only do camera to PC image transfer by a direct cable connection. That is controversial, many feel use of a reader is fine. Once I’m a 100% satisfied the images are on the PC and a backup is made, then I disconnect the camera and do an “in camera” low level format.
