Thread started 05 Oct 2019 (Saturday) 15:55
Repair question or opinions on 18-135 and 60D
Grizz1
Joined Apr 2011
Oct 05, 2019 15:55 |  #1
While on a recent hiking trip I packed all my gear into two soft case backpacks and set out with two other travelers. I used the smaller bag as a day pack and several items in it apparently were damaged at some point. First, the 18-135 auto focus would not work, though manual does. My 60 D lcd screen flashes black background when reviewing photos. Also have a 50 mm lens that the cap wont stay on as if the filter ring is bent.
I have insurance,with deductible, on all my gear,always been more concerned about total loss than slight damages.
My question, would you try to repair an 18-135 and 60D,or sell/trade while disclosing the problem?
What is the best way to get an estimate on repair and places that may do the repair or trade?
I'm guessing the cost may be more than I want to spend as my deductible is high enough that insurance will not be of much help.
If the whole bag had went to the bottom of the river I was on, it would be an easy decision and a better situation for me but it didn't happen that way.
Steve
2 Canon 60D's, 70D 18-135,-55-250, Sigma 150-500 OS,Sigma 50mm 1.4 ,Sigma 120-300 Sport,Sigma 10-20. 580EXII
duckster
Gallery: 466 photos
Joined May 2017
Oct 07, 2019 09:51 |  #2
I know this sounds silly, but the lens was not inadvertently switched from AF to MF? I have had that happen to me
John ­ from ­ PA
Joined May 2003
Post edited over 4 years ago by John from PA. (2 edits in all)
Oct 07, 2019 11:51 |  #3
On the screen, I once had an issue with a loose connector In the LCD panel. It was easy to get to the cable and get it seated again. You can find some guides on 60D repair at https://www.ifixit.com​/Device/Canon_EOS_60D (external link). Use the one titled LCD Screen Swivel Assembly. One thing that isn’t in the video is the screws are slightly different sizes so make a diagram to help keep track of the screw locations.
One other thing, any chance you are using Magic Lantern?
Grizz1
Joined Apr 2011
Oct 07, 2019 22:16 |  #4
duckster wrote in post #18940028 (external link)
It's not silly, I have done such things before but not this time. I moved the switch and nothing good happened, tried on another body and still nothing. Manuel still works, it's very difficult for me at distant objects as I wear bifocal glasses and can't seem to conquer the task. Close up objects not as much of a problem.
Steve
Grizz1
Joined Apr 2011
Oct 07, 2019 22:21 |  #5
John from PA wrote in post #18940094 (external link)
Thanks, I'll check out the link when time permits. No I'm not using Magic Lantern, not even sure what it is. I'm not very comfortable working on something such as cameras but I may not have anymore to lose and might possibly learn something by trying.
Steve
John ­ from ­ PA
Joined May 2003
Oct 08, 2019 07:07 |  #6
Grizz1 wrote in post #18940411 (external link)
You’ve used the built in diopter correction feature of the 60D? You can also purchase a correction lens for the eyepiece.
It isn’t worth having Canon fix the screen, if they even will. Some research seems to indicate that the Canon cost was about $350 as of a few years ago. KEH Camera has an Ex+ condition in stock for $367. See https://www.keh.com …mera-body-only-black.html (external link) for details on the used offerings by KEH.
kmilo
Oct 08, 2019 07:14 |  #7
The gear you've listed isn't worth much, sadly. I'd consider it a loss and start again. Maybe others would disagree.
Kris
Insulting critiques always welcomed. flickr (external link)
John ­ from ­ PA
Joined May 2003
Oct 08, 2019 07:35 |  #8
kmilo wrote in post #18940582 (external link)
As a 60D owner I’d disagree. I just returned from Europe and the 60D served me well. I also own an 80D, which I left behind since weight was a consideration.
kmilo
Oct 08, 2019 08:32 |  #9
I loved my 60D. My opinion is based on the resale value. It doesn't make sense (to me) to pay for repairs that exceed the value of the camera.
John from PA wrote in post #18940593 (external link)
Kris
MakisM1
Gallery: 50 photos
Joined Dec 2011
Oct 08, 2019 08:54 |  #10
I bought the 60D and the infamous 18-200 around this time of the year in 2011.
I am amazed it still takes pictures!... :p
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2019/10/2/LQ_1003435.jpg
Image hosted by forum (1003435) © MakisM1 [SHARE LINK]
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2019/10/2/LQ_1003436.jpg
Image hosted by forum (1003436) © MakisM1 [SHARE LINK]
Gerry
Grizz1
Joined Apr 2011
Oct 08, 2019 21:54 |  #11
I'm at 99% sure the way to go is cut my losses and start over with the one lens and 60D body. I can still get some use from the 60D as is, the lens I will likely replace soon with the newer version of the 18-135 or get a used 24-105L. I have a 70D and a 7DII , just hate to see one drop out of the line up.
My deductible is higher than buying a used lens even an open box or demo and it would have some warranty. I'm not sorry for having the insurance, it's just not going to benefit me in this case.
Steve
Ltdave
it looks like im post #19,016
Gallery: 24 photos
Joined Apr 2012
Oct 09, 2019 04:31 |  #12
we gave out daughter the 18-135 so she would have a bit more range and wouldnt need to change lenses as often (bought a 17-55 f2.8 for the wife) and during a trip to europe, it started rattling like there was a screw loose inside. it would sometimes bind up the zoom function.
i sent it in for repair and it was $100 or more i think. it started acting up on another trip; it was as if the gears inside had broken teeth and focus and zoom would bind and sometimes just skip.
its going to my work bench to play with because i think that lens is only worth about $140 used. we gave our daughter a 17-55 f2.8 of her own since shes now a bit older and more responsible (not that she mistreated the 18-135) and its a full 2 stops faster at 135mm?
id just spend the money on a new lens vs sending yours in for repair
-im just trying. sometimes i succeed
TeamSpeed
01010100 01010011
Gallery: 116 photos
Joined May 2002
Oct 09, 2019 04:44 |  #13
Also depending on which 18-135, it may really not be worth repairing. There are 3 versions.
Grizz1
Joined Apr 2011
Oct 09, 2019 18:00 |  #14
TeamSpeed wrote in post #18941113 (external link)
This is correct, mine is the original version, now wondering which is better, the newer stm or usm version or perhaps a 24-105 for replacement . My old lens served me well as a good walk around lens, took excellent photos and I'm already missing it.
Steve
duckster
Gallery: 466 photos
Joined May 2017
Oct 14, 2019 10:58 as a reply to  @ Grizz1's post |  #15
I have the 18-135 Nano USM version and I like it very well for a general use lens. Have even used it for the track & field/cross country sport use in the past
4,135 views & 2 likes for this thread, 7 members have posted to it.
1061 guests, 102 members online
