Thread started 22 Oct 2019 (Tuesday) 07:22
Lightroom won't start up.
h14nha
Gallery: 11 photos
Oct 22, 2019 07:22 |  #1
Hi.
When I try to open Lightroom I get a message saying "The Lightroom catalogue named Lightroom Catalogue" cannot be opened because another application already has it opened.
Quit the other copy of Lightroom before trying to launch.
I'm running windows.
Any ideas ???
Ian
Ian
There's no fool like an old skool fool :D
myflickr (external link)
My Gear - 7d, / 16-35mm F4 / 70-200 2.8 II / 100-400 / 300mm 2.8 / 500/4 :D XT-1 Graphite 18/35/56
John ­ from ­ PA
Joined May 2003
Post edited over 4 years ago by John from PA.
Oct 22, 2019 07:41 |  #2
Have you tried going into Task Manager and stopping all processes related to LR? If not, give it a try but after stopping things reboot, and before starting LR, again examine Task Manger to see if something is automatically starting.
You don’t mention what version of Windows, but Ctrl+Alt+Delete will bring up a screen with Task Manager listed.
h14nha
Gallery: 11 photos
Oct 22, 2019 09:13 |  #3
John from PA wrote in post #18948623 (external link)
Hi John.
I think I'm running windows 10. There's nothing shown running in Task Manager, I just opened up PS ( which I hardly ever use ) which opened up ok. My charging cable point is playing up at present so it's shutting off randomly as the battery is almost flat, so it's re-booted several times in last hour ( think I need to get all pics etc off before it dies completely ).
Thanks,
Ian
Ian
pcs
I suddenly feel very old
Oct 22, 2019 09:51 |  #4
is there a .lock file?
https://www.lightroomq​ueen.com …ng-up.33159/#post-1253083 (external link)
h14nha
Gallery: 11 photos
Oct 22, 2019 10:41 |  #5
I've just looked in Task manager, there's no file for LR there at all. What they say makes sense though, as my Laptop is crashing due to above charging issues............
Ian
John ­ from ­ PA
Joined May 2003
Post edited over 4 years ago by John from PA. (3 edits in all)
Oct 22, 2019 10:53 |  #6
h14nha wrote in post #18948703 (external link)
I think you need File Explorer to see if the file is present. Also, once open in File Explorer, make sure the option to view hidden files is enabled. It is also a good idea to enable the “see extensions” option and “see the full path in title bar” option.
See https://helpx.adobe.co​m …be-opened-lrcat-lock.html (external link) for some details about the error.
h14nha
Gallery: 11 photos
Oct 22, 2019 15:25 as a reply to  @ John from PA's post |  #7
Hi John.
Thanks for the advice, I've had parents evening tonight, so after my last post I picked kids up from school, fed them and headed back to school, so, have had no time to try your suggestions.
I will have a look in the morning and see what I can figure out, I just wanted to let you know I appreciated your help.
@pcs thanks also for your post, all help gratefully received.
Ian.:-)
Ian
pcs
Oct 23, 2019 00:57 as a reply to  @ h14nha's post |  #8
The .lock file is not an active task, just a file. LR usually installs itself in your my pictures folder. Open that folder and there are a few LR files. One of them could be a .lock file(if as John said all files are visible and you can see the extensions). This should not be there if LR was normally closed and you should delete it. (ONLY the .lock file!)
Dan ­ Marchant
Gallery: 19 photos
Joined Oct 2011
Oct 23, 2019 08:01 |  #9
It is not in Task manager... it is is the folder that your catalog is in. When you open a catalog and start editing LR writes to the file constantly. To prevent problems due to other programs editing the catalog file it locks it using the file "Lightroom Catalog.lrcat.lock". When you close LR it deletes that file and unlocks the catalog.
If LR closed unexpectedly (computer crashed) the lock file doesn't get deleted and the file is still locked so LR wont open. If you go to the folder and delete the lock file (NOT THE .LRCAT FILE !!) it LR will be able to access the catalog again.
Dan Marchant
h14nha
Gallery: 11 photos
Oct 24, 2019 09:03 |  #10
John from PA wrote in post #18948714 (external link)
pcs wrote in post #18949045 (external link)
Dan Marchant wrote in post #18949163 (external link)
Thanks all, the link John gave solved my problem. I appreciate all your inputs, that's what make this forum great.
Ian
Ian
2,547 views & 0 likes for this thread, 4 members have posted to it.
1463 guests, 127 members online
