I currently have a Feisol 3441T tripod, which is:
- 1.19kg / 2.63lb
- Height of 1.46 m / 57.48 in
- Extended height of 1.75 m / 68.90 in
- Folded length of 0.48 m / 18.90 in
I have an Arca-swiss P0 ballhead on the legs. I am 6' tall and appreciate the height, as well as the ability to handle slopes or uneven ground without being too short.
I used to use the longer center column and would occasionally extend it, but I have since switched to the short center column, so I am never using that extended height. I also never reverse-fold it (except for travel in suit case) so the folded length is a bit longer (I think closer to 22"?)
While Feisol has been great in terms of warranty, I've had a number of issues and some reoccurring issues that make the tripod a bit of a frustration to use in the field and doesn't inspire too much confidence in its durability or reliability.
I bought the tripod in 2015 and basically haven't followed too much of the tripod releases/updates since. In most of the ones I have come across, they are mainly either too heavy and/or folded length is too long OR their max height is too short.
Ignoring any budget constraints, what are some of my leading options in terms of a quality, reliable tall+light tripod?
