FORUMS General Gear Talk Data Storage, Memory Cards & Backup
Thread started 31 Oct 2019 (Thursday) 13:52
Attach Thunderbolt 2 Disk to Ethernet as a NAS
777guru
Joined Feb 2012
Oct 31, 2019 13:52 |  #1
Does anyone know if this is possible?
Pegasus R8 32Gb > 15m cable run > iMAC
Trying to relocate the disk array somewhere secure!
So far I have come across the Sonet and Promise Ethernet>TB2 adaptߘers but they seem to be only for connecting computers to the network at higher speeds.
Looking for a solution cheaper than the $500 Corning optical cable (which seems to be the only solution). The other solution is a computer running locally to the Raid Array to act as a server.
Many thanks in advance.
tim
Light Bringer
Nov 04, 2019 01:36 |  #2
I don't know much about mac or thunderbolt, but a quick google suggests that standard thunderbolt does have a maximum cable length of 3m, that the optical cables work up to 100m, and that the cables are very expensive.
I looked at the specs and can't see any Ethernet ports - 10Gbps Ethernet would possibly be fast enough to be good enough, but you'd lose some of the benefit of the product.
My opinion from what little I know is you should stick with a 3m standard cable, and use the NAS locally. If you're worried about physical security, remember a fire can burn down a whole house as easily as a room, so you really need offsite backup storage anyway.
684 views & 0 likes for this thread, 2 members have posted to it and it is followed by 3 members.
1505 guests, 130 members online
