Has anyone had their 5d4 modified to add the voice memo feature? It’s a firmware change. I miss this feature that was on my 1d bodies. Canon says it’s a five day turnaround in the US. Thanks.
cristphoto Goldmember 1,052 posts Likes: 72 Joined Feb 2010 Location: Maryland More info | Nov 18, 2019 11:28 | #1 Has anyone had their 5d4 modified to add the voice memo feature? It’s a firmware change. I miss this feature that was on my 1d bodies. Canon says it’s a five day turnaround in the US. Thanks. 1DX MK II, 5D MKIV x2, 24L II, 35L II, 50L, 85LIS, 100LIS Macro, 135L, 16-35LIS, 24-105LIS II, 70-200LIS, 100-400LIS II
apersson850 Obviously it's a good thing More info | Nov 20, 2019 02:34 | #2 If it was firmware only you wouldn't have to send it to Canon. Anders
TeamSpeed 01010100 01010011 More info Post edited over 3 years ago by TeamSpeed. (3 edits in all) | Nov 20, 2019 02:53 | #3 It was never stated it was only a firmware update, and doesn't really matter. Past Equipment | My Personal Gallery
cristphoto THREAD STARTER Goldmember 1,052 posts Likes: 72 Joined Feb 2010 Location: Maryland More info Post edited over 3 years ago by cristphoto. | Nov 20, 2019 07:13 | #4 I spoke with Canon service and it is firmware only but evidently a special type that isn't overwritten when "normal" firmware versions are updated - just like the CLog mod. The only qualifier is that the Canon Log firmware isn't installed or they will conflict. 1DX MK II, 5D MKIV x2, 24L II, 35L II, 50L, 85LIS, 100LIS Macro, 135L, 16-35LIS, 24-105LIS II, 70-200LIS, 100-400LIS II
JohnfromPA Cream of the Crop 11,258 posts Likes: 1527 Joined May 2003 Location: Southeast Pennsylvania More info | Nov 20, 2019 08:07 | #5 Sounds like something for the Magic Lantern people to investigate.
TeamSpeed 01010100 01010011 More info Post edited over 3 years ago by TeamSpeed. | Nov 20, 2019 08:29 | #6 cristphoto wrote in post #18963151 I spoke with Canon service and it is firmware only but evidently a special type that isn't overwritten when "normal" firmware versions are updated - just like the CLog mod. The only qualifier is that the Canon Log firmware isn't installed or they will conflict. It seems odd that they would "conflict", but rather they have 2 different inhouse firmware versions, each built with one or the other turned on, and they don't have a firmware version with both built in. But of course that may not quite be logical because if they could build a firmware version that had both, they could charge a $200 service with both, and they don't. So perhaps they do conflict somewhere in the bowels of the code. Past Equipment | My Personal Gallery
Nov 20, 2019 20:21 | #7 I'm not familiar with the Canon Log feature but the voice memo feature uses the Rate button for control. Does C Log use this button also? That may be the conflict. Otherwise you would think there would be a workaround to utilize both options. Another possibility is that there is only a limited amount of "hidden protected" memory and that both features could work if added on to the normal firmware. But then Canon couldn't make any profit from the feature. 1DX MK II, 5D MKIV x2, 24L II, 35L II, 50L, 85LIS, 100LIS Macro, 135L, 16-35LIS, 24-105LIS II, 70-200LIS, 100-400LIS II
| Latest registered member is semonsters 1154 guests, 136 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
