I am new to Bird Photography. My focus keeps going in and out. Was trying to shoot a bird in a tree and it was a nightmare. I'm using AI servo and spot focus. Any suggestions?
Nov 18, 2019 21:47 | #1 I am new to Bird Photography. My focus keeps going in and out. Was trying to shoot a bird in a tree and it was a nightmare. I'm using AI servo and spot focus. Any suggestions?
gonzogolf dumb remark memorialized More info | Nov 18, 2019 23:29 | #2 What lens? Do you use the back buttons to focus?
Nov 19, 2019 03:24 | #3 Small targets in low contrast situations can be tricky with AI Servo. Some bodys work better than others, my 1d mk3 was considerably better at AF in low light than my 7d mk1. Keep range as close as possible. I have added macro tubes on occasion to shorten mfd even more. Try to keep af point on eye. Setups work well if you can manage them. Put feeders in strategic locations with perches near them, and make them come to you. It is much easier when you control light, background, and distance. Randy
Canon 70 - 200 f4. Wasn't using back button.
Nov 19, 2019 10:50 | #5 Often what happens when trying to shoot birds in trees is that the lens shifts focus to something else around or behind the bird as you move slightly. Ie a leaf or twig grabs the focus and the bird moves out of focus. _____________
gonzogolf dumb remark memorialized More info | Nov 19, 2019 21:58 | #6 Gregsiem wrote in post #18962720 Often what happens when trying to shoot birds in trees is that the lens shifts focus to something else around or behind the bird as you move slightly. Ie a leaf or twig grabs the focus and the bird moves out of focus. This is why many bird photographers use back button focus for this type of shooting. You attain focus once, then release the back button. When you press the shutter, the camera doesn’t try to acquire focus again. Spot focus is also problematic sometimes if there isn’t enough subject contrast. Try using single point and see if that helps. This. Back button focus eliminates shutter stutter where you inadvertently refocus in the process of activating the shutter.
Thanks, I'll give it a try!
FrankKolwicz Member 91 posts Likes: 73 Joined Apr 2020 Location: Monmouth, Oregon, USA More info | Apr 22, 2020 18:54 | #8 Atrawick wrote in post #18962446 I am new to Bird Photography. My focus keeps going in and out. Was trying to shoot a bird in a tree and it was a nightmare. I'm using AI servo and spot focus. Any suggestions? I agree with the other respondent that the camera is probably picking up twigs and branches or other stuff in front of, behind or near the bird as it moves around and the AF automatically assumes that this other object is the subject. For that reason, I turn off automatic focus "hunting" and use manual focus to follow the subject and then let the camera autofocus just before tripping the shutter.
| Latest registered member is semonsters 1497 guests, 137 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
