icor1031 wrote in post #18984993
We have pretty good places for portraits, although I don't see what's appealing about Devil's tower.
Keep in mind though that there isn't much to shoot after all the greenery dies, like right now. There are only narrow windows after it snows during which I could capture a good portrait.
I wasn't thinking about greenery. . What I had in mind was photographing your models in rocky landscapes. . Stark rock with no vegetation. . That would be excellent for doing nudes like you've expressed interest in in past threads.
Imagine a model clinging to one of Needles Highway's rocky spires, looking down on the treetops in the distance behind her, half enshrouded in misty fog!
Or a nude model lying on the forest floor, then when you look between the tree trunks that are behind her you see Devils Tower thrusting prominently out of the horizon! . Or the same type of nude with Mount Rushmore in the background!
I'm just mentioning nudes because that is the kind of work you've said you'd like to do in previous threads ... but I think any of these scenarios would work equally well with clothed models.
How about someone scantily dressed in the open prairie at Custer State Park, feeding bright red apples to the wild burrows?!
Or a model standing up tall in a sidecar as a biker cruises the attached Harley down the middle of Sturgis during the rally, with dozens of other cycles perfectly arranged in the background to illustrate the festiveness of that event! . Yeah, I know it's unsafe and illegal to stand up in a sidecar of a moving motorcycle ..... nothing ventured, nothing gained (just do it for free so there's less chance of a liability suit).
How about the badlands, with its rocky, craggy ridge tops ..... could make for some wonderful silhouette portraiture!
Or images of a model speeding down the road on a motorcycle ... or a bicycle ... or a skateboard, shot real close-up, with some motion blur, with Devils Tower looming large right behind them in an imposing manner!
Or your model on the steep, nearly vertical face of Devils Tower, with you taking the photos from slightly above the model, to show the vast forest and meadow landscape in the sweeping distance below!
I have all these pictures in my mind's eye of what all of these possible images would look like, and they are world-class spectacular! . And they're all just an hour or two from you. . But I must admit that it is hard to put these ideas into words in a way that will communicate the concept accurately.
EDIT: This is the kind of image I had in mind ...
https://www.google.com …=692#imgrc=CU8h4ZLrZ0HcBM
... but imagine that right there between the tree trunks behind her you see Devils Tower, or Mount Rushmore.
