BuckSkin wrote in post #19015005
No doubt that is it; our Wasabi LP-E6 are 2600 mAh and our highest LP-E10 are 2000mAh
If I had of thought of them like comparing AA and AAA batteries, I would have came upon that before I got the question typed.
All of my life, I have known that the bigger the flash-light battery, the higher the mAh capacity; I should have automatically known that the same rule applied to these camera batteries.
That is what I get for thinking with my mouth open.
Just because the label states a capacity doe not mean it is true.
The cells in Canon batteries have much higher, true, capacities than what Canon labels them as.
They are not like a bottle that has a simple capacity that is easy to measure.
Here is some explanation of how Li-ion cells need to be managed in devices.
Notice both examples provide 98% depleted levels. Canon, not being morons, will not set 98% levels as the point the camera will shut down due to low battery.
That's what happens, the battery does not become fully depleted. Rather, the device measures the voltage, under an amount of load, and shut's the camera down. These Panasonic cells have a true capacity of approx 3500mAh. In a Canon 1 Series camera, which do use 18650 cells, as per these examples, the pack would be rated at about 2900 mAh or even less. It is a conservative rating to account for some ageing of the cell and more importantly the large safety margins Canon builds into their devices which shut down the device long before cells are fully depleted. Wasabi would just put a 3500MAh label on.
From this honest seller:
https://www.ebay.com.au …nasonic-Sanyo-NCR18650GA-
3500mAh-Lithium-Batteries-NIPPLE/281875641408?hash=item41a118f440
The following examples are an approximate guide only.
Example 1. Sanyo UR18650F 2600mAh, minimum Voltage is 2.75Volts.
At a 3amp continuous discharge, when the voltage under load reaches 2.75 volts, the load must be disconnected. 10 seconds after disconnection, the battery will show approx. 3.4 volts. One minute after disconnection, the voltage will rise to approx 3.5 volts. 24 Hours after, it will show approx. 3.6volts. At 3.6V 24 hour resting, the battery is 98% depleted. It will have approx 50ma remaining capacity and should be recharged before use. At 3.5V 24 hour resting, the battery is 100% depleted and any use without recharging will permanently damage the battery. At 0.5A discharge, the numbers are approx 3.1v, 3.2v and 3.5v respectively.
Example 2. Panasonic NCR18650A 3100mAh, minimum Voltage is 2.5Volts.
At a 3amp continuous discharge, when the voltage under load reaches 2.5 volts, the load must be disconnected. 10 seconds after disconnection, the battery will show approx. 3.1 volts. One minute after disconnection, the voltage will rise to approx 3.2 volts. 24 Hours after, it will show approx. 3.35volts. At 3.35V 24 hour resting, the battery is 98% depleted. It will have approx 50ma remaining capacity and should be recharged before use. At 3.3V 24 hour resting, the battery is 100% depleted and any use without recharging will permanently damage the battery. At 0.5A discharge, the numbers are approx 2.8v, 3.0v and 3.3v respectively.
Notice example 2. 3100mAh with cut off at 2.5 Volts. Third party makes a pack for canon camera and labels the pack, honestly, as 3100mAh.
Put it in a Canon camera designed with Example 1 cells, cut off at 2.75 Volts. Canon designs in safety margin so cut off set at 3.0V.
So the 3100mAh pack may now be 2000mAh.
That's what I mean about not a bottle. A 1 litre bottle is always a 1 litre bottle.
