Thread started 19 Jan 2020 (Sunday) 20:47
PHOT-ALL Lens
galelegg
Joined Feb 2017
Jan 19, 2020 20:47 |  #1
Just recently picked up a lens titled PHOT-ALL F2.8 135mm The lens is can be unscrewed apart. It has 2 f stop dials that from F2.8 to F22, the lower dial closest to the camera body seems to work the apateur, the other ?. The lens has a M42 thread mount and a 55mm filter thread, No220360E on the outer side. Anyone know about or any links to explain this unusual lens?
number ­ six
fully entitled to be jealous
Jan 20, 2020 14:25 |  #2
galelegg wrote in post #18994958 (external link)
Those lenses used to be pretty common. They're called preset lenses.
One of the rings should have detents, the other should operate smoothly with no detents. The idea is you set the detent ring to your desired f-stop, then open the iris fully to focus. When you're ready to press the shutter you close the iris to the preset detent setting.
This was because many lenses, especially long telephotos, couldn't be focused accurately at smaller apertures.
So-called automatic lenses (not autofocus, just automatic stop-down before shutter activation) became common and preset lenses pretty much disappeared.
-js
"Be seeing you."
50D - 17-55 f/2.8 IS - 18-55 IS - 28-105 II USM - 60 f/2.8 macro - 70-200 f/4 L - Sigma flash
galelegg
Joined Feb 2017
Jan 21, 2020 14:58 as a reply to  @ number six's post |  #3
Thanks number 6. I removed the aperture ring closest to the outer ring of the lens and it still worked. Attached it to my Canon 6d with Eos to m42 converter and took some photos of my granddaughter at the pool and park. Also swapped it over with a Consinon lens same focal length and aperture, could not tell the difference in the photos. These old F2.8 135mm lenses work great probably because they allow so much light to the sensor easy to hear focus beep from camera. Phot_All cost $10AUD. Consinon about $25AUD.
647 views & 0 likes for this thread, 2 members have posted to it and it is followed by 4 members.
PHOT-ALL Lens
1275 guests, 111 members online
