FORUMS General Gear Talk Data Storage, Memory Cards & Backup
Thread started 20 Jan 2020 (Monday) 22:36
External HDD/SSD Recommendations
JeffreyVB
Jan 20, 2020 22:36 |  #1
New year, new resolutions, right??? Looking to revamp my home PC setup this year. Looking for recommendations for an external HDD/SDD for archival of photos sets. Speed is not critical, but I would like some relatively fast. Want something reliable that I can use for semi long term. I work in IT, so I know nothing lasts forever, but I would like to be able to reliably use it 5-8 years with no worries of data loss. Home HDD? Portable HDD? SSD? Western Digital has always been my go to. Looked at some GTech drives on Amazon, but hey had iffy reviews. Like the form factor of the Samsung portable SSDs. This would connect to a 2018 Mac Mini, so I prefer a USB-C connection. What do you guys use? Any recommendations? Anything to stay clear off?
Canon EOS 1D Mk III |
Canon 24-105 f4L IS | Canon 100-400L IS | Canon 70-200 f2.8L IS | Canon 50mm 1.8 | Canon 1.4x MK II TC | Complete Gear List Here
davesrose
Title Fairy still hasn't visited me!
Jan 20, 2020 23:31 |  #2
More drives are still USB 3.1 (so you may need an adapter). If you’re wanting to stick with WD, the have the Duo series: I see they have a series that’s thunderbolt. It also has two drives for RAID backup (though I also think modern platter or SSD drives are amazingly dependable). For photos, a platter drive is good enough (I get around 100MBps with my platter drives)
Canon 5D mk IV
EF 135mm 2.0L, EF 70-200mm 2.8L IS II, EF 24-70 2.8L II, EF 50mm 1.4, EF 100mm 2.8L Macro, EF 16-35mm 4L IS, Sigma 150-600mm C, 580EX, 600EX-RT, MeFoto Globetrotter tripod, grips, Black Rapid RS-7, CAMS plate and strap system, Lowepro Flipside 500 AW, and a few other things...
smugmug (external link)
John ­ from ­ PA
Joined May 2003
Post edited over 3 years ago by John from PA. (2 edits in all)
Jan 21, 2020 04:41 |  #3
JeffreyVB wrote in post #18995585 (external link)
I love the Samsung T5 drives and use several in a "custom" backup arrangement. I have always purchased the refurbished 1 TB's from Best Buy. I was able to get one as low as $106. CrystalDisk info reported it had been used for about 6 hours. Having a neighbor that works for BB I asked about the "refurbished" category and was advised that the BB Geek Squad uses these drives for backing up other PC's that are returned for repair/modification/up​grades, etc Once the Geek Squad is done with the repair, the T5 drive is returned to original state and sold as refurbished. FYI, when I went to the Samsung website and registered my drive it returned information indicating I had the normal 3-year warranty. The 2nd and 3rd drives, were $125, about what they are now. Both of those drives reported less than 10 hours of use. Everything looks "new" except the packaging.
See https://www.bestbuy.co​m …k/6252145.p?sku​Id=6252145 (external link)
The T7 drives have been announced but I haven't seem them yet as refurbished and I would suspect the supply of T5's would be used up before BB started using the T7 drives for their Geek Squad.
Both the T5 and T7 are discussed at https://9to5mac.com …ng-t7-touch-review-video/ (external link) or https://appleinsider.c​om …-upon-the-t5-in-every-way (external link).
tcphoto1
Gallery: 47 photos
Jan 21, 2020 11:53 |  #4
I've had nine G Technology drives for about fifteen years and had one die. I buy them in pairs so when the one died, I simply replaced it and copied from the matching backup. At $75 for a 1TB drive I feel like I'm covered.
www.tonyclarkphoto.com (external link)
www.tcphoto.org (external link)
RDKirk
Adorama says I'm "packed."
Joined May 2004
Jan 21, 2020 12:30 |  #5
My next choice at this will be a 4-drive box, probably this Mediasonic enclosure.
I've got four drives in a NAS box, and I've got two more drives in a smaller, older Mediasonic box. There are reasons to use NAS and reasons to use a drive box.
I prefer a drive box to individual drive enclosures because the drive boxes usually can give you some limited RAID options and are usually smart enough to respond to the power status of the computer. In my experience, drive boxes are more reliable than individual drive enclosures, not to mention more compact than several enclosures.
I'm most likely going to buy four 8tb Western Digital external drives (external link), shuck the drives out of them (saving more than $50 per drive), and put the drives into the Mediasonic enclosure.
Wilt
Post edited over 3 years ago by Wilt.
Jan 21, 2020 12:41 |  #6
Consider a USB-connected (preferably USB 3.1 or later, for speed) RAID enclosure, set up for RAID 1 (data redundancy between pairs of drives) with two HD or SSD inside.
tim
Light Bringer
Jan 21, 2020 18:20 |  #7
I don't think anything will meet your requirements. 5-8 years with no data loss is virtually impossible. A disk could fail whether SSD or HDD, an enclosure could fail (they're built on the cheap), a virus could wipe the data, ransomware could encrypt everything, you could be robbed, etc.
The closest I think you'll get for archives is using AWS S3 Glacier Deep Archive Tier, at $1/TB/month with versioning enabled. It's effectively immutable, it's stored in three different data centers, it's regularly checked for corruption and repaired from other copies if required. 5TB would cost you $60 per year, so costs more than a hard disk, but is a LOT more reliable.
Alternately if you just want good quality, buy an HGST drive (external link), buy a decent quality dock, and run good incremental backup software (external link). Of course, given this is archive not just backup and data may not exist anywhere else you should get two drives, a decent case (external link), and keep one disk offsite. In that case you could do what I do, store medium res photos / videos on S3 as a second line backup.
RDKirk
Joined May 2004
Post edited over 3 years ago by RDKirk.
Jan 21, 2020 18:39 |  #8
tim wrote in post #18996190 (external link)
Not at all impossible, just not guaranteed. I have not suffered a data loss in the last six years...but I've still been backed up in multiple ways.
Choderboy
I like a long knob
Gallery: 185 photos
Jan 21, 2020 21:49 |  #9
Until this month I was using a laptop as my main PC. It's 640GB drive has not failed in it's 7 years of use. That may be an above average performance, but still common. An older laptop I have I installed a new SSD drive 6 years ago without a problem. Two Western Digital external 3.5 inch enclosures I have had also for 7 years, 1 of them has had some very minor data loss. Several 2.5 inch WD portable drive enclosures that are well over 5 years old have not had any noticeable data loss, although there may be, I just have not discovered it.
So from my experience, 5 years without data loss is more likely than not, using average drives, not best quality, with less than optimal cooling.
I'm not suggesting relying on 5 years without data loss is wise. I am saying though that rather than 'virtually impossible', it's highly likely.
I have multiple backups but have yet to need to use them.
Dave
Image editing OK
Choderboy
I like a long knob
Gallery: 185 photos
Jan 21, 2020 22:03 |  #10
I almost bought a WD My Duo enclosure until I discovered a deal breaker. I wanted to use as Raid 1, ie mirrored so I would have a backup.
However if a drive is removed, it cannot be read unless in a compatible WD enclosure.
So if you find you are unable to access data, fault finding involves buying another MyDuo just to have a device that can read the drives.
During Warranty WD will supply the enclosure, outside warranty you are on your own. You also have to try to find an enclosure manufactured around the same time as there is no guarantee earlier or later enclosures will be compatible.
If I have Raid 1, for any issues, I want to be able to remove a drive and access it immediately, not wait for warranty claim to be approved and enclosure shipped to me or have to buy another My Duo hoping it will be compatible with my drives.
Dave
Image editing OK
Wilt
Post edited over 3 years ago by Wilt. (2 edits in all)
Jan 21, 2020 22:09 as a reply to  @ Choderboy's post |  #11
In using PCs with harddrives since the first HD became available for the IBM PC in the mid-1980s, I have had 3 harddrive failures, ever...
  1. a used 5" Conner Peripherals harddrive to supplement the HD in an IBM AT in the late 1980s
  2. a brand new 3.5" harddrive provided in a brand new HP Presario desktop, about 15 years ago in the first year of use
  3. a 2.5" harddrive in a used IBM Thinkpad laptop used by my stepdaughter while a college student, about 15 years ago.
I also had a WD external USB drive have a failure of the interface, and removal of the HD itself and transfer to a dock was 100% successful in regaining access to all the data on it.
Choderboy
I like a long knob
Gallery: 185 photos
Jan 21, 2020 22:13 |  #12
Wilt wrote in post #18996293 (external link)
Single drive WD enclosures no problem. My Duo enclosures - problem.
Dave
Image editing OK
tim
Light Bringer
Post edited over 3 years ago by tim.
Jan 21, 2020 23:40 |  #13
Yes, it's true that hard drives rarely fail, if used for a reasonable amount of time, but the requirement was "I would like to be able to reliably use it 5-8 years with no worries of data loss". No worries is not possible, because data loss is always possible. Anyone who buys any brand of hard drive and considers it reliable needs to reconsider their position.
That's why I suggested a reasonably reliable brand, plus an enterprise grade storage system for either the original files or lower resolution versions. I trust S3, which is something like 99.9999999% durable, far more than any individual hard drive.
My perspective is that I design enterprise systems for government and financial institutions that cover computer, storage, and backups.
Wilt
Jan 22, 2020 00:20 as a reply to  @ tim's post |  #14
In my own history of 3 harddrive failures in 30 years of always-on harddrives, that is a failure about every 7-8 years (statistically, I should have another harddrive fail in the next few years!). The way you can improve upon statistics, it would seem, is to power-on the harddrive and plug it in to add/read data but otherwise turn it off...after all, MTBF assumes operation 24/7... the less power-on operational time, the more calendar time passes without incident, right?!
The way to have 'no loss of data' is to have redundancy of data (more than one copy of each file), with off-site storage of an additional copy of the data at an archival file copy...so you have data recovery even if your house burns to the ground or a flood saturates everything and turns the harddrives to boat anchors in the water. And you can reduce your worries about data loss with additional copies of the data stored on different units, especially if they are stored in widely dispersed locations.
Choderboy
I like a long knob
Gallery: 185 photos
Jan 22, 2020 00:53 |  #15
tim wrote in post #18996339 (external link)
Yes, I see that your response was, in fact, entirely appropriate for the OPs quote. With no backups, there should always be worry.
Dave
Image editing OK
4,400 views & 2 likes for this thread, 12 members have posted to it and it is followed by 8 members.
1504 guests, 130 members online
