Anyone have the issue of the rear display remaining on while tethering with a cable? Id like it to turn off after a minute or so while im making adjustments to the captured photos or to my scene. Im using Capture One
Feb 03, 2020 22:03 | #1 Anyone have the issue of the rear display remaining on while tethering with a cable? Id like it to turn off after a minute or so while im making adjustments to the captured photos or to my scene. Im using Capture One Canon EOS R,CANON 5D, EF17-40MM f4L,EF85MM F1.8 , Sigma 50MM F1.4 , 70-200MM F2.8, RF35MM F1.8, EF100MM F2.8 USM L.,kenko pro 300 1.4 teleconverter
calico Member 67 posts Likes: 11 Joined Jan 2015 Location: Toronto More info | Feb 04, 2020 15:30 | #2 I'll let you know if you tell me what tethering cable you got. I can't believe tether tools is the only option.
I bought a cable from amazon. Everything works fine with no issues except the rear display remains on while connected. Canon EOS R,CANON 5D, EF17-40MM f4L,EF85MM F1.8 , Sigma 50MM F1.4 , 70-200MM F2.8, RF35MM F1.8, EF100MM F2.8 USM L.,kenko pro 300 1.4 teleconverter
Feb 05, 2020 12:21 | #4 calico wrote in post #19003932 I'll let you know if you tell me what tethering cable you got. I can't believe tether tools is the only option.
calico Member 67 posts Likes: 11 Joined Jan 2015 Location: Toronto More info | Thanks. I need 15ft one. I'll probably go with tether tools. I'll report once I get it.
No problem. I don’t know if the rear display is supposed to remain on or not while tethering. But like I said everything else works just fine with no issue. Let me know. I’m also on capture one. Canon EOS R,CANON 5D, EF17-40MM f4L,EF85MM F1.8 , Sigma 50MM F1.4 , 70-200MM F2.8, RF35MM F1.8, EF100MM F2.8 USM L.,kenko pro 300 1.4 teleconverter
RDKirk Adorama says I'm "packed." More info | Feb 06, 2020 07:21 | #7 rosco1971 wrote in post #19003474 Anyone have the issue of the rear display remaining on while tethering with a cable? Id like it to turn off after a minute or so while im making adjustments to the captured photos or to my scene. Im using Capture One Thanks How are your displays set? What is the display timer setting? TANSTAAFL--The Only Unbreakable Rule in Photography
Feb 06, 2020 10:44 | #8 I'll check this evening when I get home - Lightroom CC.
I set them to 1 min. Canon EOS R,CANON 5D, EF17-40MM f4L,EF85MM F1.8 , Sigma 50MM F1.4 , 70-200MM F2.8, RF35MM F1.8, EF100MM F2.8 USM L.,kenko pro 300 1.4 teleconverter
calico Member 67 posts Likes: 11 Joined Jan 2015 Location: Toronto More info Post edited over 3 years ago by calico. | Okay. Got my cable.
It works like that for me as well. It’s when I don’t use live view on my laptop that’s an issue. Canon EOS R,CANON 5D, EF17-40MM f4L,EF85MM F1.8 , Sigma 50MM F1.4 , 70-200MM F2.8, RF35MM F1.8, EF100MM F2.8 USM L.,kenko pro 300 1.4 teleconverter
When I put the camera down to let’s say adjust exposure in capture one the LCD on my camera remains on. Again..... not using Live View. Canon EOS R,CANON 5D, EF17-40MM f4L,EF85MM F1.8 , Sigma 50MM F1.4 , 70-200MM F2.8, RF35MM F1.8, EF100MM F2.8 USM L.,kenko pro 300 1.4 teleconverter
calico Member 67 posts Likes: 11 Joined Jan 2015 Location: Toronto More info | Yeah I see what you mean. Try turning on live view in capture one and then closing it right away - that turns off camera lcd and keeps it off,
so it does the same thing for you? LCD remains on outside of live view? Canon EOS R,CANON 5D, EF17-40MM f4L,EF85MM F1.8 , Sigma 50MM F1.4 , 70-200MM F2.8, RF35MM F1.8, EF100MM F2.8 USM L.,kenko pro 300 1.4 teleconverter
calico Member 67 posts Likes: 11 Joined Jan 2015 Location: Toronto More info | Yes it stays ON but isn't that a regular state of mirrorless camera - when camera is ON one of LCDs is ON.
| Latest registered member is semonsters 1071 guests, 111 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
