Thread started 06 Feb 2020 (Thursday) 15:30
Trying to decide if my MFA is correct.
Nascar ­ Nut
Joined Feb 2004
Post edited over 3 years ago by Nascar Nut. (2 edits in all)
Feb 06, 2020 15:30 |  #1
Shooting with a 5D4 and sigma 60-600. It was back focusing when I first starting making the adjustments. I have it at -6 now. I took several bird shots from a bird blind and felt like it was pretty good. I have a couple of owl pics here to post. Both of them look pretty good in the face but the feather detail in the chest looks soft. Both shots were handheld. Both shots were shot wide open. These are 100 percent crops. I am wondering if it is still back focusing just a bit.
This first pic was at 1/250 ISO 1000 233mm
https://www.the-outdoorsman.net/temp/s​ample1.jpg (external link)
The second pic was at 1/500 ISO 200 600mm
https://www.the-outdoorsman.net/temp/s​ample2.jpg (external link)
MakisM1
Gallery: 50 photos
Joined Dec 2011
Feb 06, 2020 18:54 |  #2
Are you aware of the SS<1/FL rule of thumb? In the first one you are flirting too close, 1/250 is marginally less than 1/233. I'd shoot at least 1/500 if not 1/1000.
The other photo flouts the rule of thumb 1/500>1/600.
This rule of thumb purports to prevent camera motion being registered in the shot.
Gerry
LJ3Jim
Joined Jan 2012
Feb 06, 2020 23:18 |  #3
I think your photos are correct. On the owl, the face feathers are, well, feathers. But on the body the feathers are more like fur. I think you got what would be expected. Here's a similar shot. BTW, I'm really looking forward to the Daytona 500! I love the NASCAR season.
IMAGE: http://www.lj3.com/1dx2/owl.jpg
Image editing ok; C&C always welcome.
davesrose
Title Fairy still hasn't visited me!
Feb 07, 2020 00:22 |  #4
With long focal lengths, you’re probably getting more shallow DoF. From what I can tell from the photos, you would get more in focus with stopped down aperture.
Canon 5D mk IV
EF 135mm 2.0L, EF 70-200mm 2.8L IS II, EF 24-70 2.8L II, EF 50mm 1.4, EF 100mm 2.8L Macro, EF 16-35mm 4L IS, Sigma 150-600mm C, 580EX, 600EX-RT, MeFoto Globetrotter tripod, grips, Black Rapid RS-7, CAMS plate and strap system, Lowepro Flipside 500 AW, and a few other things...
smugmug (external link)
Nascar ­ Nut
Joined Feb 2004
Feb 07, 2020 07:54 |  #5
MakisM1 wrote in post #19005085 (external link)
Yes I am. I figured with the detail in the face being pretty good that the body should have been close to the same. That is why I started the thread. Judging from the other post stating the body feathers are more like fur then maybe it is just that.
Nascar ­ Nut
Joined Feb 2004
Feb 07, 2020 08:39 |  #6
LJ3Jim wrote in post #19005175 (external link)
That must be it. The bird shots I took after I did my MFA looked good. I used a tripod on those shots. Daytona should be a good race.
gjl711
Feb 07, 2020 09:02 |  #7
It's not a rule, it's a guideline and applicable to handheld shots without IS. IS changes things quite a bit. I would think that the formula needs to be update. Something like this.
(Shutter speed = 1/ Focal length) / (2 to the power of the IS capability of the lens).
As the 60-600 has a 4 stop IS, it should be SS = (1/600) / (2^4) or in camera terms, SS= 750 / 16 or roughly 1/60th as a minimum so 1/250 or 1/500 should be fine assuming that IS was on.
Not sure why, but call me JJ.
::Flickr:: (external link)
::Gear::
Trey ­ T
Post edited over 3 years ago by Trey T. (3 edits in all)
Feb 07, 2020 14:54 |  #8
Nascar Nut wrote in post #19004990 (external link)
Let's assume that the total depth of the owl, as it stand, is 1ft and you're about 100ft away. The online calculator shows that you got about 3ft of sharpness for 600mm; so likely you have focus issue. Try MFA to -16
It's a good photo, regardless.
BTW, for testing of MFA at 200mm+ go outside and shoot your roof shingles.
LJ3Jim
Joined Jan 2012
Feb 07, 2020 15:19 |  #9
The OP's owls really are in focus. The texture of the feathers on the body is drastically different than the head, and that's why it looks like it's not. Here's a crop from the lower left of the OP's second image. The individual fibers that are isolated in front of the darker area are nice and sharp.
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2020/02/1/LQ_1025645.jpg
Image hosted by forum (1025645) © LJ3Jim [SHARE LINK]
LJ3Jim
Joined Jan 2012
Feb 07, 2020 15:24 |  #10
Trey T wrote in post #19005509 (external link)
That's a really good tip. Thanks!
davesrose
Post edited over 3 years ago by davesrose.
Feb 07, 2020 17:22 |  #11
Sorry that my DoF comment was a bit too blanket a statement: was late, OP didn't mention aperture, don't know shooting distance, and was looking on a cell phone. One thing I have noticed that helps with perceived sharpness is high contrast. It is subjective and depends on how close you're looking....but if you're really trying to have critical sharpness: assuming DoF is safe and subject is in focus, it's safer to have less motion blurr with the focal length rule (still true with IS because of higher pixel densities), a lens's wide open aperture is slightly softer then it's optimal (2 or 3 stops down). A zoom lens is also slightly softer at maximum focal length.
Looking at LJ3Jim's crop: it looks good by itself. Another great tool we have now is software. Photoshop has some really great sharpening tools now. It can be used if you are about pixel peeping and trying to get those individual strands sharper:
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2020/02/1/LQ_1025666.jpg
Image hosted by forum (1025666) © davesrose [SHARE LINK]
Canon 5D mk IV
MakisM1
Gallery: 50 photos
Joined Dec 2011
Feb 08, 2020 09:16 |  #12
gjl711 wrote in post #19005364 (external link)
Α 'rule of thumb' IS a guideline. Nobody will give you a ticket if you break someone's rule of thumb (unless you break his actual thumb...).
All I am pointing out is that you don't want to be at the ragged edge (of the 'rule of thumb') when you try to do calibration work. Personally, I would switch IS to OFF when doing calibration (AFMA) work, and use a tripod and a remote.
Anyone that uses a shutter speed less than the 'rule of thumb' relying on the IS for camera motion while doing AFMA is asking for trouble.
Your mileage may vary...
Gerry
Choderboy
I like a long knob
Gallery: 185 photos
Feb 08, 2020 19:43 |  #13
MakisM1 wrote in post #19005833 (external link)
Agree. I use beanbag and remote shutter for such tests. If hand holding a 600 I would use 1/2500 sec or faster with IS/OS off. If not enough light for that fast wait until there is or use beanbag and remote or timer. Then you can be confident results are worthwhile.
Dave
Image editing OK
Nascar ­ Nut
Joined Feb 2004
Feb 08, 2020 20:20 |  #14
When I did my MFA my IS was on and on a tripod with remote. I like the shingle idea to use for MFA.
Nascar ­ Nut
Joined Feb 2004
Feb 08, 2020 20:26 |  #15
I think I am going to shoot some more stuff and check my results before I start messing with the MFA again. I am up to the Sax-Zim Bog now in hopes of photographing some more owls. My first day didn't go to well.
2,749 views & 10 likes for this thread, 9 members have posted to it and it is followed by 5 members.
1039 guests, 107 members online
