Anyone with actual experience using a CF to SD adapter in a Canon 7D, I would like to know of your experiences and what you have learned works and what does not.
I have both, a 7D and a 7DMkII.
I have a varied selection of SD cards of various brands/models and capacities.
I have this CFxSD adapter = Qumox Type 1 Extreme CF Adapter:
https://www.amazon.com …sc=0&ref_=lv_ov_lig_dp_it![]()
Here is a condensed version of my findings:
With any SD card that I have tried, SD card inserted in the adapter and the adapter then inserted in a USB-connected card reader, I can read and write to the card flawlessly, with no noticeable difference in speed compared to the same SD card inserted straight in the reader; this holds true regardless of whether the combination works in the camera or not.
That being said, I have found the 7D to be quite finicky and also somewhat erratic as to which of our SD cards it will recognize and which it will not -- in the adapter, of course.
I have also found that the 7DMkII is not quite so finicky; it will often accept and recognize SD cards (in the adapter) that the 7D will not.
Any SD card that the 7D will accept, so far it has always accepted; and, the SD card/adapter combo seems to be almost as quick to respond as a normal CF card.
If I put a SD card in the 7D and it tells me to remove and reinsert the card or format in the camera; I may as well just make note that that particular SD card is not going to work in the 7D, as no amount of re-situating is going to change it's mind; either it accepts it right off, or it is not going to.
The 7D will accept a 64GB Delkin Advantage, but will not accept the 128GB Delkin Advantage.
It refuses to accept 32GB Delkin Select
It will accept 32GB Transcend 600x 90MB/s and not accept 32GB Sandisk Ultra 80MB/s
The above is just a sampling of what the 7D will and will not recognize in the CF adapter.
Like I already said, several - but not all - of the cards that the 7D rejects, the 7DMkII will readily accept.
I have tried to fool the 7d by formatting the rejected card in various other cameras and also in the computer, but I have not had any success at this.
Considering my own findings, I am going to say that the 7d owners that give these CF adapters wonderful reviews just happen to have an SD card that their 7D likes; and, those 7D owners that leave negative reviews just happened to have SD cards that the camera did not like; I am sure this holds true regardless of camera model.
I have also read in many comments about the CF adapters something like "If you want an adapter that works, you are going to have to spend a lot more money and get a quality adapter"
I have two things to say about those type comments: First, I don't believe the comment writer has ever used a CF adapter - high quality or not - as I have searched the internet over and all I can find are relabeled examples of the one that I already have.
And second, none of these people ever leave a link to, nor mention a brand name of, these high-priced quality adapters; if such an adapter exists, I would like to be pointed in that direction.
Also, concerning these CFxSD adapters of ALL brands, there are always several reviews that tell horror stories of the adapter bending or even pulling out pins from the cameras card slot; with this information burned into my brain, I carefully inspected the holes in the adapter with a strong magnifying glass and thoroughly tested it by numerous insertions and removals from a card reader before I ever inserted it in the actual camera.
The particular adapter that I got must be okay in this regard as I can tell no difference between inserting/removing it and a normal quality CF card.
By the way, I debated on whether this discussion should be in the memory card section; but, I put it here instead because I am seeking answers specific to using the adapter in Canon cameras ONLY.
Thanks for reading and all help is appreciated.
Please share your CF adapter findings.
