I wanted to take a moment and write once more, a few weeks later. After your post, and my reply, I actually went around looking to see what some of my friends and colleagues were using as a gimbal solution. I actually discovered -confessions time- a whole range of active gimbals at a somewhat affordable price.
And while much of my original answer stands, I have found that the Moza Air 2 is a great DSLR gimbal, with up to 9lb payload capacity, and three axis stabilization, lots of useful modes, etc. I picked one up, and so far I cannot wait to use it out in the field. Doesn't have the complications of a much more complex rig (suspension or the super-bionic Arri-Trinity rig, more on that here: https://www.youtube.com/watch?v=6JLbVQNS74w
), and at the same time it provides what most affordable gimbals could on smaller device, but on full body DSLRs with a couple lbs of glass attached to them, a monitor, etc.
Definitely worth a look at:
Official site- https://www.gudsen.com/moza-air-2
Amazon- https://www.amazon.com …-Mirrorless/dp/B07P9WRBYX
Lots of comparisons with the DJI Ronin S, and actually some rather favorable reviews when side to side.
Is it worth the $550? Depends. Like everything in photo/video, it is a tool, and it will be worth whatever time and use it is given.
It does offer a great level of stabilization, and many of the features of the big rig stabilizators (single axis follow/lock, etc). Does it remove the famed "ninja" walk? No. You can introduce a lot of vertical movement by walking carelessly or running normally while using this type of gimbal/stabillizator. This is where I originally mentioned a cheaper, more introductory solution might be a good entry to the world of stabilized motion. Also having hands off the camera can be tricky, depending on what you are doing. iFocus module -I got it and use it for both pulling focus and zoom when needed, is really good too.
Anyhow, thought I would addend my original notes, I felt that this type of gimbal would offer you a more realistic solution (any in its Class, like the Zyuhn Crane, DJI Ronin, Moza Air or AirCross, etc) without having to go to either extreme.
Hope this helps.
